586,847 active members*
2,460 visitors online*
Thread: How do I?
Results 1 to 7 of 7
    Aug 2014
    161
    How do I?
    So here is another part im looking for assistance, or guidance. its a new traverse gear case for my atlas lathe, i tried a couple things that of course didn't work, i did the dotted lines and adaptive but it said Drive Curves Missing and wouldnt make a tool path. remember i have no Z so i would like to cut the depth in one pass. thanks
    Aug 2014
    161
    Re: How do I?
    heres the file, from V26
    Aug 2014
    161
    Re: How do I?
    The machine is actually cutting the part now, but it didn't tool path exactly what I envisioned...
    Sep 2009
    105
    Re: How do I?
    2D Advanced Pocket Adaptive Rough.
    Aug 2014
    161
    Re: How do I?
    My tool path only had 2 or 3 Z lifts, however it cut full width around the boss on both sides which I would have liked to avoid. Mainly cause I wanted to cut the full .375 depth in one pass since I don't have automated Z, with the current post there is an M01 before and after every Z move, which accounts for a cycle start press everytime, so I try to make my tool paths with as little Z moves as I can. Thanks for the reply, what size cutter did you program in yours? I used a 1/2"
    Sep 2009
    105
    Re: How do I?
    Quote Originally Posted by chevydyl View Post
    1/4"
    Aug 2014
    161
    Re: How do I?
    I since made a remote cycle start button so the Z lifts are not as much trouble. Here's the finished part.
    Attached Thumbnails Attached Thumbnails 20151031_021419.jpg   20151031_021146.jpg
