Originally Posted by
munzerxo
Hi - well I actually own a 3D printer, and it has limitations, that is why I want to switch to CNC milling.
[There's a wide variation in 3D printers, and the common hot plastic extrusion type doesn't make surfaces fine enough for jewelry. There are others, though, that work much better for that: either hot-wax deposition type printers (eg: Solidscape) or photo-catylyzed resin printers (B9 Creator) produce models with good surface detail in materials that can burn out in a "lost-wax" casting process.]
Can you please recommend 3 cnc mills?
