586,761 active members*
7,429 visitors online*
    Jul 2007
    72
    6061 Barstock Distortion?
    Recently we had a job made from 8" x 1.6" barstock finished to OAL 1.5" x 2.98"ID , 8"x1" OD (flange), and 3.438" x .5" OD (hub) , the 8" od didn't quite cleanup all around.
    In the first machine the part was drilled, faced, and the ID was cut to size, held in softjaws
    In the 2nd machine the part was held on an ID collet faced to length, and both 3.348" & 8" ODs were cut.
    In the 3rd machine the part was again held on an id collet 4 holes were drilled, 3 holes tapped, and a 3/16 slot was milled in the 8" x 1" portion of the part. from the od to approx. a 6" dia.
    I am confident after several samples and many measurements the ID the size was not affected from the id holding,
    After machining on the mill(3rd step) the ID shrunk .002", which is over our allowed tolerance. The 3.438" od also shrunk but was within tolerance.
    The location of the shrinkage was directly in line with the slot and 1 of the 4 drilled holes
    I think it is from slotting the part and am curious if anyone has run into similar situations with this type of material or any other, or was this a fluke.
    An thoughts on this would be appreciated.
    CHEERS
    I'm just a butcher masquerading as a machinist
    Jun 2005
    232
    Re: 6061 Barstock Distortion?
    Some times material has stress in it.
    You may need to rough it and leave everything .01 under size
    and let the part sit overnight and then do the finishing.
    I think you problem is with the slot cut it before finishing the
    od and id.
    I bought some chinese 7075 aluminum last year .
    I needed about 1500 lbs of it .It was a dollar cheaper
    than the alcoa aluminum .I thought great ill put an extra
    $1500 in my pocket.
    I ran a few hundred pieces the next day they were .0018
    out of round, all were scrap. Sent the rest of the material
    back and bought the expensive alcoa and everything was fine.
    Lesson learned.
    Tim
  1. Feeding barstock back through the sub spindle of Star
    By Victor864-ARCP in forum CNC Swiss Screw Machines
    Last Post: 06-12-2013, 08:57 PM
  2. Supplier for Octagonal tube/barstock
    By Deviant in forum MetalWork Discussion
    Last Post: 02-12-2011, 06:24 AM
  3. Distortion compensation
    By hanaitm in forum Uncategorised CAM Discussion
    Last Post: 11-17-2010, 01:40 AM
  4. Cutpath distortion
    By KevinClardy in forum PlasmaCam
    Last Post: 01-29-2008, 08:22 PM
  5. cutting off 304 ss barstock
    By mtechserv in forum MetalWork Discussion
    Last Post: 01-13-2006, 02:32 AM
