So I'm still getting the wrong diameter when I do lathe programs. I usually end up being around 0.010" to small when I run the part. Below is the code I did for a 2" diameter part I programmed. As you can see it goes right to 2" on line 9 (My lathe uses diameter mode). But since the tool is an 80deg bit shouldn't it move out slightly to accommodate the tool nose radius? I'm not sure what I am doing wrong that is casing me to be undersized on all my parts. Any ideas?
I tried changing the cutting angle of the insert on the tool page, but that made no difference in the post.
O0100
(Machine Setup - 1 Turn Rough )
(TOOL #1 )
N1 G40 G99 G18 G20 G90
N2 T0101 M06
N3 M41
N4 G50 S1000
N5 G96 S500 M03
N6 M08
N7 G00 X2.5 Z0.
N8 G71 P9 Q10 U0. W0. D.06 F.015
N9 G00 X2.
N10 G01 Z-3.3996
N11 G40
N12 M01
N13 M09
N14 G00 X10. Z0.
N15 G00 Z5.
N16 M05
N17 M30
