586,553 active members*
3,485 visitors online*
    Aug 2015
    4
    Larken replacement parts
    New member here. I bought a Larken 24/24 back in I believe 2004(?). I must say it has performed incredibly well. My only problem is once in a while the X or Y axis will get "stuck". I have read that the machines this old had Pacific Scientific steppers that were almost under powered for the machine (100 oz-in. torque). I have two questions:
    1. Does anyone have the replacement part number for the X and Y lead screw nuts? I believe Larken uses Kerk Leadscrews (Now Haydon?). I could take the nuts off and figure out the lead, etc. but I would rather order the nuts and then replace and not have to be down for a week. I think Larry has stated that he specially machines the Z nut. I really can't complain - almost 11 years and I have not changed or had to replace anything on this CNC router. (I have rebuilt 2 Bosch routers on the spindle).
    2. To address the potentially under powered motors, has anyone replaced their motors? If so what brand, holding torque, phase current (amps), and voltage. I believe the motor drivers in my controller are only rated for 2 amps to drive the motors. The Pacific Scientific motors are labelled P224RHS-LNN-NS-02 with 1.8 degree step, 3.1 amp, bipolar parallel. I have great success with this machine and would like to boost the motor power without changing anything else.
    At some point I know I will have to update to a windows based controller. For now I am OK with windows 98 for my controller. Any help would be greatly appreciated. Thanks.
    Aug 2015
    4
    Re: Larken replacement parts
    After looking at the most recent build pics of the Larken shop, I have found what appears to be the X and Y lead screw nut part number. There is a bag of the nuts with Kerk part numbers on them.
    ZBX-ANR-050-0333-8200
    ZBX - anti-backlash style
    A - Triangular Flange Mount
    N - No lubricant
    R - Right Hand thread
    050 - Lead Screw Diameter - 1/2"
    0333 - Lead Screw Pitch - 0.333"
    8200 - Not sure - I think it is a customer assigned number to make ordering easier for Larken
    Aug 2015
    4
    OK.....I have another question. Larken had told me I could go to new motors and drivers and told me to set the drivers to 800 steps/turn. I checked my Larken 24/24 today in regards to the lead on the leadscrew. I measured the linear motion on one motor turn and it was .333 in. This does not seem to compute with Larry saying to set the drivers to 800 steps / turn. There is no gearhead or gearing so wouldn't a 1.8 degree step motor and a 0.333 in lead equate to 600 steps / turn?
    Any input would be appreciated. Thanks.
    Maybe he means set the drives to 1/4 step, or 800 steps per motor revolution.
    Aug 2015
    4
    I believe you are correct - Thank you!
    Feb 2007
    966
    Yes, the drives are set to 800 steps/rev so the x and y axis (3tpi screw) has 2400 steps/inch. On the Z axis the screw is 5tpi so its 4000 steps/inch.
    Larry
  1. Parts from Larken?
    By Rhodan in forum Larken
    Last Post: 04-24-2009, 04:10 AM
  2. Replacement Parts?
    By JMFabrications in forum Haas Mills
    Last Post: 02-28-2008, 03:45 AM
  3. X3 replacement parts
    By CR250Greg in forum X3/SX3/G0619/G0463
    Last Post: 07-30-2007, 04:41 PM
  4. BOSS 5 Replacement Parts & ?s
    By braidmeister in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2006, 04:36 AM
  5. 9X20 Replacement Parts
    By kdoney in forum Mini Lathe
    Last Post: 04-06-2006, 03:35 AM
