586,732 active members*
2,717 visitors online*
Page 4 of 5 2345
Results 61 to 80 of 91
  1. #61
    Jan 2007
    869
    Re: Gib Adjustment
    The big machines can actually adjust the backlash via the position on the leadscrew.
    Our little controllers don't have that functionality --- yet...
    Wade
  2. #62
    Mar 2008
    256
    Re: Gib Adjustment
    I'm not sure what you mean "adjust the backlash via the position on the leadscrew".
    When I was playing with Mach it seemed to simply move the axis an extra (configurable) distance every time the direction reversed. The big problem I had was that playing with the "acceleration" associated with that distance resulted in a weird balance of non-linear/non-circular motion vs. a heavy "bump" every time the axis reversed. How bad the effects were also depended on the feed rate in play at the time. It seems that a smooth, effective implementation of backlash compensation would have to anticipate axis vector transitions and integrate the compensation into the transition acceleration profile. Instead it seems like the software attempts to deal with it independently of the current state of motion, and I believe that is where the ugliness comes from.
  3. #63
    Feb 2007
    1538
    Re: Gib Adjustment
    Guys - Backlash compensation during active machining has limited effect on a light machine as cutting forces at least during heavy machining can move the work by the amount of backlash plus flex.
    But anyway on a dovetail gib machine like the Tormach, slideway racking and associated slideway assembly flex is often a bigger issue and this does not operate in a linear predictable manner that can be compensated for.
    Keen
  4. #64
    Mar 2008
    256
    Re: Gib Adjustment
    Keen, I'm afraid that's mostly utter nonsense. Properly implemented backlash compensation on well-built machines of any size or design will improve both geometric and dimensional accuracy.
  5. #65
    Feb 2007
    1538
    Re: Gib Adjustment
    Quote Originally Posted by flick View Post
    I agree with you regarding well built machines - yes that does apply to all serious VMC's.
    But remember the Tormach's are just low cost lightweight machines built to much lower tolerances. Really they are just well made mill/drills with dovetail slides.
    Don't get me wrong - they are great value machines for the money.
    Keen
  6. #66
    Jan 2007
    869
    Re: Gib Adjustment
Name:	Slack for iOS Upload.jpg
    Going for a ride.
  7. #67
    Apr 2016
    109
    Re: Gib Adjustment
    Wwendorf, please keep us posted on how this turns out. Controversey or no about what you are spending to get the machine trued up, you are breaking some ground most of us havn't seen done to a Tormach. I for one am very, very interested both in how the pro rebuild turns out and if they have anything to say about what the issues are that they find.
    Thanks!
  8. #68
    Feb 2007
    1538
    Re: Gib Adjustment
    I second that ! Keen
  9. #69
    Aug 2013
    980
    Take a video!
    Quote Originally Posted by keen View Post
  10. #70
    Jan 2007
    869
    Re: Gib Adjustment
    Hi Guys, I spoke to the guys who are rebuilding my machine. They are buttoning it up today! I'm going to be picking it up tomorrow, but they want me to spend some time with them going over the machine and checking tolerances. They said that it was basically riding on 4 points as the ways and gibs were very poorly scraped. The ball screws were tested and appear to be just fine, so at least I didn't need to send them in for re-manning.
    I'll post a report here when I get a chance to play with the mill after I get it back and setup.
    Possibly even do a video. I didn't ask them to do any photos as I didn't want to annoy them and cost myself anymore money, but I will be asking them for an itemized list of stuff they had to do to it so I can both report here and send a copy to Tormach (who is also interested in what I am doing).
    Wade
  11. #71
    Feb 2007
    1538
    Re: Gib Adjustment
    Cheers Wade - look forward to your report!
    Keen
  12. #72
    Jan 2007
    869
    Re: Gib Adjustment
    Hi Guys,
    Got my mill back home and the enclosure installed back on it. I have to level it up again and am waiting on a machinst level.
    The crux of the problem with the mill was that the table was basically attached by 3 points on each axis. They had to scrape the ways and the gibbs. After doing that, they also tested the ballscrews which they declared fine, so I didn't need to wind up sending them in (saved $2k there).
    When I went to pick it up, they actually spent about 3 hours with me after we hooked up the control. I've got her down to .0006" on X and Y and .0004" on the Z. I'm WAY good with that. They weren't able to get any better on the backlash due to the way the table was manufactured, and more specifically, the way the ball nuts were attached. (I didn't ask details on that. It made sense so I didn't get to into the brush.)
    They said that the scraping done from the factory was very minimal, definitely not a "job well done". The table runs perfectly flat now as well.
    So there it is. Didn't get the .0001" they were talking about, but the construction of the table precluded that.
    I'm happy and hope to be cutting some chips this weekend.
    Cheers!
    Wade
  13. #73
    Aug 2013
    980
    Thanks for the report. Let us know how she cuts.
    Quote Originally Posted by wwendorf View Post
    Hi Guys,
    Cheers!
    Wade
  14. #74
    Dec 2008
    740
    Re: Gib Adjustment
    Hi Wade
    Good to hear you're pleased with the results! I don't recall anyone on the zone boasting less than .0004 (I know I'm not). It's interesting that your Y is now one of the best axes and that Z is also extremely good - I found Z to be the trickiest.
    Step
  15. #75
    Jan 2012
    97
    Re: Gib Adjustment
    Wade, I'm glad it has worked out well for you.
    At the Tormach Open House last week, I had a long talk with one of their technical support specialists. He had confided with me that, although they have several QC personnel at the manufacturing and assembly points, there are times when stuff slips through the cracks. Engineering changes will be made only to have manufacturing revert back to the old design. Unfortunately, when QC is checking a final assembled machine, they cannot determine if some process or assembly was done to spec. An example of a hidden defect was my discovering on the cabinet fan motor and the coolant pump motor, the wires were just twisted and taped.
    I can't help wondering how many other machines have the "three point contact" problem. It might explain some of the problems with my 770.
    R J
  16. #76
    Feb 2007
    1538
    Re: Gib Adjustment
    Thanks Wade.
    Just a quick reply - this type of error is what I also found when I dismantled my latest 1100. The slideways then 'rack' or 'sway' when the direction is changed.
    This can also be caused by a twisted base - looks like in your case it was caused by factory errors.
    Please let us know how it measures up when you have it ready to go.
    Cheers Keen
  17. #77
    Mar 2008
    256
    Re: Gib Adjustment
    Nice!
  18. #78
    Jan 2007
    869
    Re: Gib Adjustment
    I'm happy to report success! I have eliiminated the tick marks at 12,3,6,and 9 oclock positions. Roundness of a 1" dia interpolated hole is .0005 to .001.
    The machine cuts like butter now, better than it ever did before.
    Plus side is that the tech who reworked my machine said he'd be happy to come out in 2 months and teach me to adjust gibs the way they do it.
    Tonight was my first cut with it since I got it back. My day job kicked my ass and so did my weekend.
    Anyway, I'm up and running again.
    Wade
  19. #79
    Apr 2013
    1788
    Re: Gib Adjustment
    How did you measure the roundness of an interpolated hole? I'm familiar with the V-anvil micrometers used to determine the roundness of a rod but I've never seen a similar instrument for testing holes.
  20. #80
    Jan 2007
    869
    Re: Gib Adjustment
    Just a digital caliper. It works to give me a good idea of where it's at.
    Wade
Page 4 of 5 2345
  1. Gib Adjustment
    By pilot001 in forum Fadal
    Last Post: 10-25-2011, 05:50 PM
  2. BMC-20 Box Way Gib Adjustment
    By fasto in forum HURCO
    Last Post: 03-22-2010, 09:35 AM
  3. DV-59 Gib Adjustment
    By HBFixedGear in forum Hardinge Lathes
    Last Post: 04-21-2009, 04:02 AM
  4. Way adjustment on TM1
    By f1jdm in forum Haas Mills
    Last Post: 12-01-2008, 07:50 PM
  5. QC Nut adjustment
    By zcases in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2007, 03:10 AM
