587,023 active members*
4,128 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Which operation for a T-Slot ?
    May 2007
    37
    Hello,
    I'd have to mill a t-slot similar to the one you can see in the attached 'drawing'. I have the tool designed and added to the tool crib. Ihave the 3d file of the part but don't know which operation to use for this.
    The tool has a diameter of 100mm and is 10mm thick with a radius of 5mm.
    Which operation to use ?
    Thanks in advance !
    Richard
    Jun 2014
    52
    Re: Which operation for a T-Slot ?
    How large is the stock now?
    "The one who follows the crowd will usually go no further than the crowd..."
    -Albert E.
    May 2007
    37
    The size is:
    Width 10"
    Height 4"
    Length 15"
    Sample file attached
    May 2007
    37
    Here is a model of the tool to be used
    Richard
    Attached Files Attached Files
  1. one slot is coded other slot is not there
    By cwaugs in forum Uncategorised CAM Discussion
    Last Post: 05-06-2011, 03:00 AM
  2. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  3. t-slot
    By fatboy55 in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2007, 11:28 PM
  4. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
