586,991 active members*
3,811 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Spindle ON/OFF kbmm-125 and MTBB6X bob
    Hey guys, so while I know this break out board cannot control spindle rpm through mach3 since it doesnt have 0-10v capabilities, I'm wondering if you know if it could simply turn the spindle on and off leaving me to manually control spindle speed. Most of my work is in aluminum anyways so I usually keep it pinned.
    The specs for this bob are lean;
    6 axis Breakout board
    Built in C-class Optical-coupler
    High quality with Surface-mount Tech
    CNC Compatible software MACH3,DeskCNC, Rutex,Linux EMC, TurboCNC
    Built in DB25 male connector
    Output Pin P1,P2,P3,P4,P5,P6,P7,P8,P9,P14,P16,P17
    Input Pin P10,P11,P12,P13,P15
    GND Pin P18-P25
    Power supply +5V DC
    Package Includes
    1 x Breakout Board adapter
    1 x DB25 Cable 6', 2 meters
    Would I be able to designate a pin to the inhibit terminals on my kbmm board for on and off control?
    Sorry I'm sure it gets asked all the time, been trying to search but most of my results are about the c11 board and full spindle control. Thanks in advance.
    Apr 2003
    354
    Re: Spindle ON/OFF kbmm-125 and MTBB6X bob
    According to KB, you should to be switching mains power on & off to the KB to turn the motor on & off (for safety reasons.) You'd definitely need relays for that.
  1. KBMM-225D and 2.8HP Treadmill Motor
    By rusmannx in forum Benchtop Machines
    Last Post: 09-18-2014, 06:42 PM
  2. kbmm-125 diode blown
    By kuyote in forum Benchtop Machines
    Last Post: 07-03-2014, 07:50 PM
  3. Why can't the MX3660 be used as a potentiometer for a KBMM-125
    By Wiggles84 in forum Benchtop Machines
    Last Post: 02-26-2014, 02:49 PM
  4. Kbmm-125 c6 rr2-u relay
    By mr.andaya in forum Benchtop Machines
    Last Post: 10-22-2013, 08:11 PM
  5. G540 and KBMM-125
    By maddios in forum Gecko Drives
    Last Post: 02-27-2012, 08:02 PM
