586,966 active members*
2,791 visitors online*
Hybrid View
    Jan 2006
    37
    4th Axis on a Bridgeport EZ Trak DXII
    Can anyone tell me how to put a 4th axis on a EZ TRAK DXII. I see the C and S Axis in the PFM file under tune. And I have an extra Drive card and servo . But I do not have software for the control;
    Nov 2004
    3028
    Re: 4th Axis on a Bridgeport EZ Trak DXII
    The software will not support it. Do you need a true 4th axis or will a programmable indexer do?
    Jan 2006
    37
    Need a true 4th axis .
    Apr 2013
    40
    The EZ Trak software was never designed to read a 4th axis. The C and S axis were basically setup as spindle and some sort of like air/coolant system. If you wanted a 4th axis readable, you would have to use a seperate DRO.
  1. Bridgeport EZ Trak 3rd axis addition question.
    By jwoelfel79 in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2015, 07:49 PM
  2. Bridgeport ez-trak dxII
    By fullbore in forum Bridgeport / Hardinge Mills
    Last Post: 03-12-2011, 05:41 PM
  3. Ez Trak DXII
    By Zombiestomp in forum Bridgeport / Hardinge Mills
    Last Post: 02-05-2010, 01:15 AM
  4. Bridgeport EZ Trak axis problems
    By ZootCapri101 in forum Bridgeport / Hardinge Mills
    Last Post: 01-18-2008, 03:57 AM
  5. EZ-Trak DxII Cutting D's Instead Of O's
    Last Post: 02-14-2006, 07:21 PM
