586,391 active members*
3,094 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Interchange Chart for LM components
    Apr 2006
    362
    Does anyone know where I can find an absolutely reliable and comprehensive guide or chart so that I can take my AGW20H 93851-6064 and determine precisely what other blocks I can use in its place. I need two of these and I may not be able to find that exact block. And that's fine. But I can't afford to order some other brand of 20mm block and then find that it won't fit my rails. Any help will be appreciated.
    Oct 2006
    The best interchange / cross-reference I've found for linear guides is from the IKO site, although it is more of a good summary, not detailed:
    http://www.ikont.com/Catalogs/IKOLin...angeChart2.pdf
