586,975 active members*
3,042 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4020 will not CS today
    Feb 2011
    423
    I've only had this mill for a couple weeks and want to thank those of you who did help me initially get it running.
    This is a 1997 4020HT , Everything was fine last night when I shut it down.
    This afternoon after booting the control it will not cold start.
    All axis' will jog to the markers and after keying in "CS" the screen goes blank for a couple seconds and will
    prompt for returning to the last fixture position. Keying in yes or no will cause the screen to again go blank.
    After the video recovers a few seconds later the prompt has reverted back to "jog to cold start" .
    Should you try to jog the axis' at this point they will rapidly jump around a 1/4" .
    I caught a glimpse of an onscreen message on one occasion that had something to do with memory.
    It was so quick I couldnt see all of it.
    There however isnt any error codes or messages on pg. 47 of the menu.
    Does anybody have any ideas?
    Thanks again
    Re: 4020 will not CS today
    Replace the battery back-up......First use the setp command and write down all values..... then use the BL command and write this down.......If its an AC servo motor machine look at the SV command and write those values down....... The battery is really easy to replace but on most machines it is soldered on. Look up the memory clear procedure, it is in the manual available at Motion Machine Technologies LLC. | TEST zero the memory, replace the battery, replace the parameters and you should be good to go.
    Apr 2005
    1194
    Motion Machine Technologies LLC. This is the one your looking for. Motionman has some good advice. I don't want to come across as nancy know it all but don't worry about the parameters there are only 30 of them or so. Very few to enter and also don't worry its multiple choice...lol.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Apr 2005
    1194
    Motionman have you worked on any 104D machines? Have you ever gotten one successfully going? I see very few left on the market and with a little tweaking...hmm.
    Feb 2011
    423
    Havent had any issues since the previous noted day.Anybody ever have humidity issues with these machines?
    Apr 2005
    1194
    Yes and virtually every fadal that shipped from the factory had bags of dessicant in the control cabinets. Get some in there.
  1. I got V27! TODAY!
    By Big Chips in forum BobCad-Cam
    Last Post: 09-06-2014, 12:40 AM
  2. today on the CNC
    By justCNCit in forum DIY CNC Router Table Machines
    Last Post: 02-18-2010, 02:10 AM
  3. New today in UK
    By artificerjon in forum European Club House
    Last Post: 04-14-2009, 08:37 AM
  4. CNC-Today.com wants to know what you think
    By Team Pierson in forum Trade Shows / Webinars / Other Events
    Last Post: 01-25-2008, 01:49 PM
  5. need help today
    By thesaent14 in forum DIY CNC Router Table Machines
    Last Post: 07-01-2006, 04:32 PM
