586,553 active members*
3,338 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport EZ Trak 3rd axis addition question.
    Mar 2015
    Alright I currently have a 1998 EZ-TRAK setup running version 6 which has been updated sometime before I bought it with an EMI motherboard. after doing some extensive reading it seems that there are not a lot of people who have personally done the conversion or those who have say that it is difficult at best.
    From what I have read I am led to the following:
    1. The mechanical portion can be picked up from Elrod Machine
    2. Need Z axis motor (MT30H4-44)
    3. Need a axis pwr amp (MHB12020-00)
    4. Wire axis pwr amp according to Dwg. 1943390 (Rev, J)
    Here is where I need some guidance:
    1. Reading has led me to believe the motor needs both motor & encoder plugs (encoder not shown in the Dwg. referenced above) so in 3 axis mode it will mill properly and also needs the z axis scale when in two axis mode for feedback but on the AXS BOB does the encoder cable JP4 plug? And where does the other one plug into?
    2. The Z axis limit switch should plug into JP11 but there is already something plugged into it. What would be occupying this on a 2 axis machine?
    3. Lets say I get far enough in the conversion that I need to power up the machine, how do I get it to recognize the new 3rd axis?
    Jun 2007
    129
    Re: Bridgeport EZ Trak 3rd axis addition question.
    The EMI update came with a software disk that will load the correct 3 axis software. I also sent you a PM.
    Mar 2015
    Reabdet21 tried to send a pm. Your inbox is full
  1. Bridgeport ez-trak stupid question
    By nealg in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2022, 01:53 PM
  2. Bridgeport 3-axis ez-trak mill programme help
    By tsaul in forum Bridgeport / Hardinge Mills
    Last Post: 06-19-2013, 11:36 PM
  3. Bridgeport EZ Trak Flashdisk question:
    By marx911 in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2010, 02:09 AM
  4. Bridgeport EZ Trak axis problems
    By ZootCapri101 in forum Bridgeport / Hardinge Mills
    Last Post: 01-18-2008, 03:57 AM
