586,808 active members*
7,949 visitors online*
Results 1 to 7 of 7
    Oct 2007
    67
    Fanuc 6T issue
    Hello,
    A machine Tsughami with Fanuc 6t is giving a random issue. During normal operation either spindle will stop working or tool turret will stop working but not both. Is this related to the distribution cards in front or some other issue. Any help would be appreciated.
    Thx
    Jun 2004
    511
    Re: Fanuc 6T issue
    Any messages or alarms?
    Oct 2007
    67
    Re: Fanuc 6T issue
    No alarm or messages.
    Oct 2007
    67
    Re: Fanuc 6T issue
    The problem is more severe now. Turret & spindle working in jog mode. While as soon as a program is run either turret does not move to target tool or spindle does not rotate. Must be related with control. Any procedure to refresh & reinstall control & parameters?
    Aug 2011
    2517
    Re: Fanuc 6T issue
    could be a dodgy turret switch. if the index switch is not working or stuck in a mid-rotate position the machine will wait for it to complete. the check for it only happens in memory mode.
    bad turret switches are pretty common in old machines so that's something to check.
    Dec 2009
    965
    Quote Originally Posted by hell_pk View Post
    Hello,
    Thx
    For the turret problem i would search for clamping sensor that is not checked for confirmation in jog mode.
    For the spindle would be also the clamping sensor that i think is going off from vibrations during rotation.
    Oct 2007
    67
    Re: Fanuc 6T issue
    Problem does seem to originate from turret since TERR(diagnostic bit 215.0) is 1. Tracing it leads to TERR8(diagnostic bit 15.0). This in turn leads to TEND & TAGR bits with TAGR(bit 216.1=0 meaning target position uncoincident). Any things to consider while checking dodgy/problematic turret switch. Any diagram that would help in this case as it will be the first time turret will be opened. Thx
  1. Replies: 8
    Last Post: 09-25-2014, 02:58 PM
  2. Fanuc 0M, M19 Issue..
    By gearsoup in forum Fanuc
    Last Post: 12-15-2012, 08:52 PM
  3. Fanuc Ot DNC issue
    By BrendanF in forum Fanuc
    Last Post: 07-19-2009, 06:57 AM
  4. FANUC 0M ISSUE
    By mccullyengineer in forum Fanuc
    Last Post: 05-27-2009, 01:25 AM
