587,019 active members*
3,863 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach3 and Spindle motor from China running in slow RPM
Results 1 to 8 of 8
    Jul 2015
    6
    Hello to all .
    I am phasing a problem with my new 400 watt spindle that i can't resolve any advise it will be helpful.
    I have bought the following spindle motor from ebay with now instructions at all of course ,i manage to make it work with mach3 and my CNC through the pin port No.16 were was free ,i can control the speed of the spindle , on and off function also works .. but the motor running slow to the maximum speed (14000RPM).
    As i measure with my multimeter from the port no.16 i get maximum 2.5volt when the maximum speed placed on mach3 spindle control screen, but i thing that the PWM motor speed controller wants 12volts maximumto give the maximum speed on the spindle...
    any ideas it would be appreciated.
    Aug 2006
    673
    Re: Mach3 and Spindle motor from China running in slow RPM
    have you tried changing the "steps per" setting in the motor tuning control? Is your max and min spindle speeds set in the pulley set-up? I assume you're not using a tach feeedback are you?
    Jul 2015
    6
    Yes i have try to change the steps and pulley setups with any luck .. always the same results i get the spindle runs too slow, and no i have not using any tach feedback
    Mach3's PWM output varies from 0-5V. If you're measuring it with a standard meter, it probably won't read the voltage correctly, as it's a pulsed signal.
    If you really need a 12V PWM signal, then it's not going to work,
    You might be able to use a board to convert the PWM to a steady voltage and connect it where the pot goes. If you connect the pot, what voltage is the pot sending at max rpm?
    15362
    pelo13
    How fast did you expect it to run, most of these are just a regular DC brush motor, & are only good for 3,000 RPM to 12,000 RPM
    The collet chuck is just mounted on a standard DC brush motor, these motors are not designed to be used as they are for a spindle
    Spindle Motor:
    Work voltage: 12-48VDC
    Rotation speed: 3000-12000r/min
    Power: 400W
    Torque:500mN.m
    Insulation resistance:>2Megohm
    Dielectric strength:400V
    Motor Length : 186mm
    Diameter:52mm
    Axis collet Length: 48mm
    Diameter of Axis collect holder:16mm
    Repeat accuracy: 0.01-0.03mm
    ER11 collect: 3.175mm
    Power supply Specification:
    Input:AC110V/AC220V±10% 50/60Hz
    Output: DC48V 10A
    Adapter power: 480W
    Dimension:L130mm * W98mm * H38mm
    13pcs(13 size ) ER11 PRECISION SPRING COLLET set:
    Gripping Range 0.5MM to 7MM (3/128" to 17/64")
    Run-Out Tolerance 0.015MM (0.0006")
    First Class 1065 Carbon Steel
    Hardened & Precision Ground
    Wide voltage PWM DC brush motor speed controller:
    Applies to DC12-60V low voltage permanent magnet brushed DC motor
    Operating Voltage: Wide Voltage (DC) DC12V-DC60V (Max 65V)
    Control mode
    A: Default potentiometer control (5K-100K),defaults 10K;
    B: MACH3 -PWM speed control signal input, external PWM input requirements: level 3.5-12V VPP, frequency 1K-10KHZ, suitable for MACH3 spindle speed control.
    4. Rated current: 10A, overload and short circuit protection current 12A. (Over-current cut output, overcurrent indicator flashes, the potential light is off, overcurrent lift).
    5.soft-start function. Prevent excessive current caused by the motor and power damage (default 0 seconds soft start), 0-5 seconds adjustable.6.Control power: 12V120W, 24V240W, 36V360W, 48V480W, 60V600W7.Dimensions: Length 75mm * Width 75mm * high 42mm 8.Pulse width modulation range: 0% -100%
    Mactec54
    Jul 2015
    6
    yes i know that.. with the pot connected i get the right RPM's (3000-12000).. but when i control it from mach3 the speed is too match lower..
    I check out the voltage on the pot i get 0-5v on maximum speed .. and i think the only solution is that i get i board converter as you say , but i don't understand why they sell the MACH3 -PWM speed controller with set when isn't 'plug&play' .. or maybe we are missing something here..
    15362
    Quote Originally Posted by pelo13 View Post
    They sell a lot of things that don't work as described, they also sell a lot of very good things as well, you have to carefully choose a good supplier as to what you buy, this is easier said than done,in most cases
    Your problem seems to be what is coming out too your speed control, which is from Mach 3 through your Breakout board, try Mach 3 set in step/dir & measure the output from the Breakout board, you should have 0-5v You may have to do this through a different pin/output on your Breakout Board, if you are getting 0-5v, then it should only be a setting adjustment in Mach 3 to get the PWM to give you the 0-5v needed output, even try the pulley setting at 2
    What Break out Board are you using
    Mactec54
    Jul 2015
    6
    I use this one
    https://drive.google.com/file/d/0BwI...ew?usp=sharing
    i use pin 16 right now but i will try another pin as you suggested
  1. Replies: 0
    Last Post: 01-15-2015, 10:50 AM
  2. Mach3 ref all home motor down't stop only slow
    By blackdebian in forum Mach Software (ArtSoft software)
    Last Post: 08-21-2014, 08:48 PM
  3. New Quirk = Spindle running SLOW, at wong RPM??
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 05-14-2014, 06:14 PM
  4. Chinese CNC 3040T Slow Spindle Motor
    By Viking50 in forum Chinese Machines
    Last Post: 09-05-2013, 07:06 AM
  5. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
