586,728 active members*
3,273 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Disable overtravel alarm (regardless of control)
Results 1 to 17 of 17
    Jun 2008
    113
    Heya.
    Is there any way to disable the most annoying overtravel alarms? I would like the axis to just stop, quietly.
    (In case it is control dependant, the particular control in my case is 18i)
    Thanks!
    Jun 2004
    511
    Re: Disable overtravel alarm (regardless of control)
    You should be able to set stored stroke limits that will just throw an 500# fault. Just back off the limit and reset. If you are hitting the hard limits, you need to set your parameters 1320 and 1321.
    Feb 2009
    6028
    No, the annoying soft ot will always be there on a Fanuc.
    Sent from my A3-A20FHD using Tapatalk
    Aug 2011
    2517
    I worked and programmed CNC machines for 30 years and hardly ever got OT alarms.
    Sure now and then, but it was always something stupid that I did that caused it. After
    you do it a few times you learn and then just don't do it, or do it right.
    you need to use and program the machine that way it was designed.
    what are you doing (wrong) that is giving you the alarm?
    is it manual or in-program?
    1792
    It is a safety feature. Do not dislike it.
    1792
    Set soft limits a few mm before hard limits, as already suggested. Hitting hard limits is indeed annoying.
    Feb 2009
    6028
    Even the soft limit alarms are annoying. I hit them all the time when I'm doing metrology checks on Fanuc while setting up. Okuma is better for this, it just hits limit and stops. No alarms, no hitting reset.
    Dec 2009
    964
    it is easy in your 18i control to edit the ladder and take off the OT alarms from alarm list.
    if you do not have a password that protects the ladder from editing you can do it but before just back up it.
    2932
    I believe that parameter 1301 bit 4 = 1 will cancel the alarm without resetting once you back off the soft OT.
    Jun 2008
    113
    OK, thank you everybody. Fordav11: The problem is that with our Fanuc lathe it is easy to hit the X+ limit due to the rather limited X-axis travel and when turning large workpieces with a tailstock it is just best to move the turret as far as possible before indexing (during manual set-up, quick tasks etc.). I'm not looking to *disable* the soft limits, but suppress the message (and the need for reset). Just like our machines with an Okuma control, they do not nag about the limits.
    Anyways, it's not like the end of the world
    1792
    Did you try 1301#4 = 1, as suggested by Dcoupar?
    Jun 2008
    113
    I just read the answers, so will try it on monday and let you know
    May 2014
    174
    Quote Originally Posted by myhäje View Post
    And I wonder, what ever happened.?
    Jan 2018
    what's news?
    Apr 2013
    Quote Originally Posted by thekondrat View Post
    what's news?
    1300.1 it’s not labeled but it’s between LMS and OUT parameter. The overtravel will still work but the alarm will not pop up. The machine will not let you continue past your overtravel limit set in 1320’s.
    Attached Thumbnails Attached Thumbnails 85A2FB64-C0AF-49D0-93E9-70D00D492B05.jpg
    Mar 2012
    75
    Quote Originally Posted by Jacek3743 View Post
    Excellent info- super handy. Wasn't pointed out in the Fanuc parameter manual for my machine.
    1792
    It is not listed in model C parameter manual, but listed in model D manual.
    Designated as NAL (probably implying No ALarm)
  1. Citizen A-20 overtravel alarm
    By jslater20 in forum CNC Swiss Screw Machines
    Last Post: 08-30-2023, 08:49 PM
  2. Z + Overtravel alarm
    By cd0426 in forum Fanuc
    Last Post: 01-11-2023, 07:38 PM
  3. alarm 510:overtravel X+
    By hell_pk in forum Fanuc
    Last Post: 02-29-2016, 09:28 PM
  4. alarm 500 overtravel
    By Datech in forum Fanuc
    Last Post: 04-07-2014, 10:08 PM
  5. I have an overtravel alarm
    By eclarkmx in forum Fanuc
    Last Post: 09-04-2010, 12:43 PM
