586,852 active members*
2,046 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 6 TB G28 disable parameter ?
    May 2014
    36
    Hi Guys ....
    I have a slight problem .
    I have an Ikegai with a fanuc 6tb control .
    Problem is sometimes i make a mistake with my G50 AND G27 co-ordinates .
    So the machine goes home after on the G27 command but lest say my Z value is not the same as the Z on the G50 then the machine gives me an alarm (All good)
    So i change the value and make sure they are the same as the G50 values ...ok fine .
    PROBLEM is that now the machine ISNT actually home anymore so if the tool is now 50mm forward and i cycle start SMASH ...OR CRASH !!!
    I have a Wasino with a 6t control aswell and that lathe wont run a program unless the machine is at home !
    I was wondering if any of you know about a parameter that i could change on the Ikegai so that it works the same as the Wasino .
    Im sure there is a prameter because the Wasino doesnt allow me to use G28 .
    Please guys any info would be appreciated ...ive scrapped 2 parts in 2 days and its costing me a few bucks now .
    Im not too bothered about using G28 i just want to make sure the machine is home before any program will run ...if possible .
    May 2014
    36
    Re: Fanuc 6 TB G28 disable parameter ?
    Heavy Metal ...you have a PM .
    G28 U0.0 W0.0 works when you want to send the turret home and its slightly easier than G27
  1. Parameter to disable transmission / gearbox
    By Ydna in forum Haas Mills
    Last Post: 02-12-2015, 01:13 AM
  2. disable the scale in fanuc OGC System
    By ramas2_07 in forum Fanuc
    Last Post: 11-14-2013, 05:38 PM
  3. Axis disable in fanuc 31i- madel A5
    By srimurthyb in forum Fanuc
    Last Post: 10-31-2012, 09:33 AM
  4. Fanuc OTT C Axis Disable - URGENT HELP PLEASE
    By BryCAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2011, 06:15 PM
  5. Fanuc 16i-M 4th axis disable
    By MDR32 in forum Fanuc
    Last Post: 07-23-2010, 01:07 PM
