Originally Posted by
Roadsidejobshop
Hello people,
I've been trying to decide on which type of mill to build and considering my availability to machines and tools, I have ruled out a RF45 clone, a fixed gantry mill (unfortunately, i really like them) and have decided on an inline CNC mill for small aluminium parts production. The bed is 200x350mm and has a Y-axis travel of about 250mm, gantry height is about 200mm(between table and gantry bottom) and X-axis gantry has a travel of about 350mm. Z-axis should have a travel of 150mm.
All rails are HIWIN HGR15, frame is made out of steel tubing, current weight (in the model) is around 101.3 kilograms (i'm guessing around 160-170 with all the parts).
I also did some preliminary FEA testing on the individual parts (after having calculated the cutting force for the largest cut I could imagine taking, 6mm endmill, 2mm cut depth), which came out to about 800 newtons. Using this I found that all parts have very small deflection (Gantry was highest, around 0.012mm when 800 newton force applied to upward, leftward and inward to the front face(2400N total).
Anyways, thanks for the feedback, motors are planned to be salvaged NEMA 23, which will be later swapped out for either closed loop steppers or maybe even servo motors (if i ever get that much money).
Thanks!
