586,655 active members*
3,114 visitors online*
    Jul 2009
    86
    Shift + Coolant?
    Hey guys,
    I was reading through the MIll manual and noticed that pressing shift+coolant on the control will turn the auto air gun on and off. I do not have an auto air gun, however I do have thru-spindle coolant and thru-spindle air. Does anyone know if there is a way to change shift+coolant so it starts one of those two options instead? That would be nice.
    Also the manual says to turn on TSC before the spindle speed command. What is the reason for this?
    Thanks!
    Nov 2006
    490
    Re: Shift + Coolant?
    An interesting idea, I wonder the same thing myself. You could probably wire it up if you identified the output relay responsible for the air gun.
    The TSC system uses a rotary union that must be stationary to provide the initial sealing action, only afterwards can it start spinning. It's actually written into the M88 code as a failsafe, so the spindle will come to a stop when you execute an M88 command regardless of whether you want it to stop or not.
  1. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  2. G50 zero shift
    By 03clipse in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-13-2010, 12:24 AM
  3. G50 Shift?
    By RC-CNC in forum CNC Swiss Screw Machines
    Last Post: 12-04-2009, 01:26 PM
  4. Anyone need help on 3rd shift??
    By AMCjeepCJ in forum Milltronics
    Last Post: 12-22-2005, 08:34 AM
