586,761 active members*
7,640 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Optimum BF46 CNC conversion with Kflop and Teknic servos.
Results 1 to 11 of 11
    Jun 2013
    12
    Cool Optimum BF46 CNC conversion with Kflop and Teknic servos.
    Hi All, Just wanted to share, I just completed CNC build for BF46 heavy duty CNC machine. I was amazed by the precision/performance of Teknic servos.
    Machine works quiet while working on different kinds of operations. Build a very compact CNC motion controller based on Dynomotion Kflop in Mini-ITX computer cabinet.
    I will post pictures soon and try to include some videos.
    May 2013
    455
    Re: Optimum BF46 CNC conversion with Kflop and Teknic servos.
    Looking forward to seeing your pics, I have been thinking about buying an Optimum BF46 for a while now and doing a conversion
    Jun 2013
    12
    Jun 2013
    12
    Here is the link to video.
    https://www.youtube.com/watch?v=xOUe8dh4fGk
    May 2013
    455
    Looks awesome! Nice work.
    Apr 2004
    733
    Nice work!! Did you put ballscrews in or used the original screws? Those brushless servos are nice, what continuous torque? I had to use 4:1 pulleys on my servo driven X3 mill. Yours seem to run just fine direct drive.
    Jun 2013
    12
    Hi , I used ballscrews SFU25-5 . Teknic brushless servos are SDSK3441 for Z and SDSK3421 for X and Y axis. These motors are directly connected to ball screws. Also X3 mill is way smaller than this mill. This is 1100LB heavy duty precision milling machine.
    Mar 2014
    62
    Hi Harish,
    I'm working towards a CNC conversion on a BF46 too, and have a few questions for you.
    -Which rated speed of each servo did you buy? Assuming the YouTube video is of max rapids, I'm guessing 730 rpm on Z and 1090 rpm on X and Y.
    -Did you put a brake on the Z axis? If not, do you have any problems with Z falling down when the servo isn't powered up?
    -What did you use for bearings in your screw mounts? Did you re-use the Optimum bearings, like they do in their own ballscrew kit?
    Thanks!
    -Steve
    Jun 2013
    12
    Hello Windscreen,
    My youtube video is showing ~90IPM. I will post another video with max IPM ~145 I can achieve using these servos. yes servos are 730 for Z axis and 1090 RPMs for X and Y.
    I didn't use any brakes, never had any issue Z axis falling down whether servo is on or off.
    I used original bearings from Optimum, I believe those are AC bearings.
    Let me know if you have any more questions.
    Apr 2004
    733
    Quote Originally Posted by harishom View Post
    Your brushless motors have more continuous torque than my brushed motors I used but also your machine has much more mass to move.
    Most of the time servo motors are geared down for more torque. At first I ran my servo motors direct drive. They had no problems rapid moving the table around but at high cutting loads (steel), they started to get hot. I fixed the problem by using pulleys, trading Rpm for more torque. Now the motors don't get even warm to the touch.
    Those teknic servos are high performance so you probably won't have a problem like I did.
    Jun 2013
    12
    Adding more pictures.Attachment 324898Attachment 324900
  1. Optimum 180x300 CNC Gang tool conversion
    By belli in forum Mini Lathe
    Last Post: 11-25-2015, 10:51 PM
  2. Info on Ballscrews for Optimum BF46
    By MrBean_pm in forum Linear and Rotary Motion
    Last Post: 11-01-2013, 06:57 PM
  3. Optimum BF46 Centroid retrofit
    By yolklab in forum Benchtop Machines
    Last Post: 04-01-2012, 04:33 AM
  4. Optimum BF20 G0704 Conversion
    By Winnfield in forum Benchtop Machines
    Last Post: 08-07-2011, 12:16 AM
  5. Optimum BF20L CNC conversion
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2009, 05:09 PM
