586,950 active members*
2,766 visitors online*
IndustryArena Forum > CNC Electronics > PIC Programing / Design > Pic based servo motor drive
Results 1 to 8 of 8
    Jul 2005
    107
    I have started working on Pic based servo motor driver to interface with MACH 2/3 software the PIC will take input from Mach as step and direction and compare it with encoder pulses. It will generate pwm output to drive bridge for servo motor .I want to keep it simple as the motor tunning is done through Mach software. Pic will be 18F452 or 458.
    Ahmed
    Nov 2006
    6
    can anyone help me for how make interface circuit between mach3 and dc servo motor with 3-axes mill machine?
    Feb 2004
    466
    Quote Originally Posted by newton View Post
    Well its not polite to hijack a thread, and maybe the question was not properly formulated.
    There is a Break Out Board (BOB) which is the interface between the PCs parallel port that is used to pass STEP/DIR signals to the Drive Module which will spin the servos aided by the encoders which signal the servo position back to the Drive (closed loop system)
    Now back to the PIC servo drive thread.
    Konstantin.
    Nov 2006
    6
    thanks for intersted and replying me
    i know bob , i read this pdf but
    first :i can't find it in my country
    second: i have to do this circuit , it's my graduated project and my doctor 'll refuse this Suggestion
    Jul 2005
    442
    Motor tuning can't be done in Mach and have a system that responds quickly without oscillating.
    For more information take a look at the Elm controller thread in the opensource forum.
    Are you an EE or an ME?
    Aaron
    Nov 2006
    6
    thanks for help
    i'm a mechatronics engineering
    Feb 2007
    966
    My Viper servo drive is a Pic based servo drive, so is the Rutex.
    It took be about 8 months to get it perfected.
    http://www.larkencnc.com/viper/index.shtml
    Aug 2007
    7
    Allegro Micro has some good app notes and data sheets for stepper and DC motor drives.
    www.allegromicro.com
