Hi
Could anyone give me an example code for helical milling on this machine,
I need to mill a 13mm diameter hole radially through the wall of a part, OD is 40mm, ID is 35mm, hole centre is 15mm in from face in Z
Using a 10mm end mill
Doosan Fanuc i control
I could drill but I have several different size holes to do, and learning this code would be very helpful.
