586,967 active members*
2,836 visitors online*
Page 1 of 3 123
Results 1 to 20 of 51
    Apr 2012
    72
    Light metal milling machine
    Hi DIYers, after the last build has been finished with great success. I have a long break and confidently start on a new project.
    Here is my design:
    Travel: XYZ: 400x300x300mm
    Weight: 1 ton.
    4 Axis.
    Parts on hand:
    25mm rolled linear guides (Schneeberger)
    25mm diameter double nut ball screws
    CT3 steel from my neighbourd.
    NT30 spindle
    Alpha step ASD20A-C + ASM911AC
    Here we go:
    Assembly:
    The second day:
    The third day:
    It's 340 kg now.
    Thanks for reading.
    Khoa
    Sep 2005
    1195
    Re: Light metal milling machine
    Can you put dimension on the block.
    Apr 2012
    72
    Hi asuratman,
    Here is the 3D file of this machine. I hope that you can read it with Inventor 2014.
    https://www.fshare.vn/file/6IQY96R54SFH
    You can switch the language to English
    The dimension of blocks are:
    Machine based: 450x900x150mm.
    Y axis: 620x240x100mm.
    Z axis: 995x240x170mm.
    30mm thickness steel.
    For x axis, the T slot table is 300x600x70mm.
    Apr 2004
    5742
    That's looking good; it should be up to the task of light-duty metal milling. Have you noticed any warping in the steel from welding?
    Andrew Werby
    Website
    Apr 2012
    72
    I didn't see any wrapping from my last build. It's archived 0.005mm of tolerance for all xyz axis travel.
    I use two soldering-irons on both hand and welding both welding side at the same time with 30mm weld beads. Then switch to other side of the part and do the same. It makes the parts look dirty (the weld beads are not equal) but It can prevent wrapping a little bit. It was 41 Celsius while I was welding the parts.
    Apr 2012
    72
    Here a some pictures of parts will be used for this machine:
    It costs me about $700 for all of these.
    Khoa
    Apr 2006
    169
    :banana::wee::banana::cheers:
    Mar 2004
    1661
    Quote Originally Posted by khoac3 View Post
    Hi asuratman,
    I have no clue what to click to download, everything is on Vietnamese...
    But the machine looks really good and with that thickness of material I wouldn't say "light metal milling". I am doing light metal milling in my steel beam router.
    Apr 2012
    72
    Hi, just pay attention to the right top corner of your browser and look for Vietnamese Flag icon. The language is there. I "guess" it can mill carbon steel nicely with light step over.
    My last build travel is 180x300x300mm (YXZ) and weight around 750kg. It's mainly used for brass milling parts but can cut steel pretty well.
    Apr 2012
    72
    Here are some updates of my works:
    Only welding and grinding the parts.
    Thanks for reading,
    Khoa
    Apr 2009
    5516
    Great work... But calling this a "light" milling machine?! Hehehe
    Oct 2010
    1189
    It is Because of Light i guess ; (-
    Gesendet von meinem SM-G800F mit Tapatalk
    Apr 2012
    72
    I think the industrial milling machines at this size will be much heavier than this machine. So It should be light compared to them.
    My next DIY project is a mix of concrete and metal to reduce the cost. It will be a heavy machine. 2->3 tons, three times heavier than this project, he he.
    Oct 2010
    1189
    you ar right i repaired an bridgeport 412 which has similar travel which is around 3,5 tonns ,..
    Apr 2012
    72
    Some updates on the light milling machine Y axis is ready to go.
    Spindle based :
    Aug 2009
    291
    I just ~love~ that tap handle!!
    Apr 2012
    72
    It's my hand made tap handle )
    Apr 2012
    72
    Continue working on this machine, here are some of my updates
    Z axis:
    Y axis and some "pin" for epoxy filling:
    YZ assembly:
    Thanks for watching
    Aug 2009
    291
    I know, that's what's so cool!
    I was at the steel store a couple weeks back and saw some really heavy walled tubing that had me thinking about this build.
    Thanks for the updates! Looking forward to shots of work on the head!
    Apr 2012
    72
    Now I'm working on the DIY grinding machine. I need a larger size to ground XYZ base before I put the rails and ball screws on.
    Here is the X axis for the based. Just use what I can get from a scrap yard near my house:
Page 1 of 3 123
  1. spectra light milling machine
    By dcorga in forum Mini Lathe
    Last Post: 12-18-2014, 06:41 PM
  2. Milling machine for metal shoe mold
    By DhakaMould in forum Chinese Machines
    Last Post: 04-25-2014, 02:26 AM
  3. metal milling machine conversion
    By i-make-robots in forum Uncategorised MetalWorking Machines
    Last Post: 06-02-2011, 08:57 AM
  4. Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal
    By SCG11762 in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2007, 02:08 PM
