586,531 active members*
2,926 visitors online*
IndustryArena Forum > CAM Software > Hypermill > The Metric System
Results 1 to 5 of 5
    Mar 2006
    371
    The Metric System
    When I start a new file it always defaults to mm. How can I change that to inches?
    Dave
    Mar 2006
    69
    Open a new file, start the hypermill interface, before you do anything else click on the setup icon (Looks like a wrench) and set to imperial, on the bottom of that dialog box is an icon of a disk with a blue check box on it (I believe a mouse hover reveals something about 'default' something) click on that icon, save that file.
    Mar 2006
    371
    Well that was easy! Thanks. :rainfro:
    Apr 2006
    19
    The same "Save As Default" functionality can be applied to jobs as well. For example: If you wish to have a 3D Profile Machining job always open up to Y-axis direction cutting, just select your desired setting and save as default.
    Doug Wyrybkowski
    OPEN MIND Technologies USA Inc
    Aug 2017
    3
    Re: The Metric System
    My customer makes STEP files in English, but I do everything in Metric. When I open the file in Hypermill, the dimensions are wrong. Before, I have scaled the part, but this is ridiculous since STEP files already know what units they are. I don't have to do this in SolidWorks, Fusion, etc.... Is there an easier way to do this?
    Thanks, Ed
  1. Metric suppliers for metric metal dimension
    By jeffrey001 in forum Canadian Club House
    Last Post: 02-10-2014, 05:49 PM
  2. Replies: 0
    Last Post: 01-19-2014, 02:18 PM
  3. Replies: 0
    Last Post: 01-06-2014, 11:15 PM
  4. Replies: 0
    Last Post: 07-26-2013, 08:38 AM
  5. Converting DSP controller system to Mach based system.
    By Marwell in forum Machines running Mach Software
    Last Post: 12-20-2008, 12:00 AM
