586,807 active members*
8,082 visitors online*
    Aug 2006
    20
    Focus distance of Chinese laser lens and other quirks
    Hi there,
    I recently bought a Chinese K40-III laser cutter and I'm still debating with two difficulties.
    I don't know the focus distance of the lens, it's a 12 mm lens but when I asked the seller about the focus distance the seller didn't even knew what I was talking about! Is there a simple way to find the focus distance?
    I have th machine cutting almost perfectly, the two quirks I have still is that the machine cuts perfectly in a box of 10 cm x 10 cm from home point but beyond that it needs more power to cut through, is there a way to correct this (mirror alignment is perfect and I clean them every day)?
    Second is the debris, this might be normal in a machine like this, I built air assist and a honeycomb table but most of the ashes remain in the material, is there a way to optimize this (get rid of the burnt wood/card)?
    Thanks in advance
    Nov 2008
    382
    Re: Focus distance of Chinese laser lens and other quirks
    hi there
    first make the ramp test ( put a strip of wood across the table then raise the right side about 6mm up then cut a straight line with 25% power and 10 mm speed then look where the line is the thinnest measure on this point the distance from the material to you laser head , that's the focal distance what you always need to hold)
    second the airassist stream must blow in the cut.
    greeting
    waltfl
  1. Focus lens and beam expander for 10.6 um laser (20mm diam)
    By JulianDR in forum RFQ (Request for Quote)
    Last Post: 08-09-2013, 12:18 AM
  2. how to adjust my new 1.5" focus lens on my co2 laser cutter
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-05-2013, 11:04 AM
  3. Laser alignment (bad focus lens?)
    By fantasy2 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2011, 06:44 PM
  4. lens focus distance
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2011, 05:36 PM
  5. Laser lens focus, which one fits ?
    By VBLietuva in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-14-2010, 03:56 PM
