586,655 active members*
3,075 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > LinuxCNC and HSMXpress.. Z axis keeps moving above part and machining air..
    Apr 2015
    27
    Question LinuxCNC and HSMXpress.. Z axis keeps moving above part and machining air..
    Hey Guys,
    So I have successfully engraved a piece of wood with LinuxCNC (the default gcode that comes up in linuxCNC) however after designing a part, post processing with EMC in hsmxpress and setting the start path etc.. my z axis jumps up 25mm and starts trying to do the work 25mm above the part. Im thinking its something with the post processor. Has anyone else encountered this? If so, what were the steps they took to get around it?
    I had made a little more complex part to begin with, failing that, I ended up just making a box with a cutout and it still does the same thing. I have attached the solidworks part (zip file as a SLDPRT file isnt supported to be uploaded.. weird) along with the gcode (again .ngc isnt supported, so .txt it is..) . Would anyone who is more educated in this area care to take a look please?
    Thanks for your help.
    Cheers,
    SR
    Attached Files Attached Files
    Re: LinuxCNC and HSMXpress.. Z axis keeps moving above part and machining air..
    My guess would be your tool length offsets. (G43)
    Apr 2015
    27
    thanks heaps for the reply, I think your 100% right, .. when I setup my tooling, I set most of the lengths of the tool to be 25 to 50mm.. them homing the z axis from the tool touching the workpiece. So it makes perfect sense. Such a newbie mistake.. My idea was after each tool change to keep homing the z axis.. should I continue to do this but set the tool length offset to be 0mm?
    Actually, I think it would be better practice to home the z axis without a tool in it and measure the correct tool lengths, the problem is with this is I only have 1 arbour and a 63mm facemill so if i change the endmill then it will set it at a different height eachtime.. this is why I see people with a few arbours with different tools in them...
    thanks again..
  1. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  2. Z AXIS - Moving bearings or moving rails ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 02-28-2012, 06:22 AM
  3. Moving Part Independent of 4th axis tbl *Tormach*
    By HLF Ordnance in forum SprutCAM
    Last Post: 02-14-2011, 01:42 AM
  4. Replies: 11
    Last Post: 05-31-2010, 07:03 AM
