586,555 active members*
3,329 visitors online*
Results 1 to 20 of 20
    Mar 2015
    35
    thin plastic material for engraving
    Hello
    does anyone know where to get some sort of flexible & thin black & white plastic material?
    max 0.5mm would be ok, front surface black and would engrave white
    Sep 2014
    128
    Re: thin plastic material for engraving
    brand name "lamflex"
    Mar 2015
    35
    Quote Originally Posted by ELaser View Post
    Thanks, i also found Gravoply. But i can't find any place selling either of these in small quantities.
    Mar 2015
    35
    Mar 2004
    413
    Rowmark, Innovative plastics are two brands I get.....
    Get it from Ability Plastics: Ability Plastics HOME
    I think their laserable plastics are the thinnest,.... not sure how thin the two color plastics go.
    Be prepared for a WIDE variety of colors though, from plain to patterned to metallics !
    Chris L
    Mar 2015
    35
    Quote Originally Posted by datac View Post
    Yes, but where can i actually buy these.. i think the manufacturers only tend to sell in larger quantities to business. I need like 2 x a4 sheets!
    Mar 2004
    413
    Ability will sell it to.. just give them a valid credit card and your on your way. If you think your future will require more, you should buy the sample books of actual pieces... lots and lots of variables.
    I dont know of any supplier with a web cart though.... seems these guys are still living in darker times !
    Jan 2008
    940
    Bf plastics carry it
    Mar 2015
    35
    Quote Originally Posted by fixtureman1 View Post
    Found couple of places that sell it, but none that ship to Finland. Or take paypal or other payment method i could use.
    Sep 2014
    128
    Mar 2015
    35
    Need something that is 0.5mm / 0.020" or under
    May 2015
    4
    Anybody have any pictures of this material engraved? I have a client looking for something very similar. Thanks!
    Sep 2014
    128
    Sep 2010
    717
    0.5mm is very thin. I know where to get 1.5mm thin/thick..
    Maybe you could get white plastic & paint the surface black..(Or the other way around)?
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    May 2015
    4
    That's definitely thicker than 1/32".
    jumbieindustries.com
    epilog 50w (for now)
    Sep 2014
    128
    didn't say it wasn't.... for the record it's 1.6 mm lamflex
    Mar 2015
    35
    It thought about that. Well actually using some sort of sticky-backed plastic.
    But as this stuff is available, i rather would go with it. I don't trust that the paint would last as long as this type of material.
    Quote Originally Posted by hub View Post
    Sep 2010
    717
    Lamtekno Oy - LF7110 valkoinen-musta
    0.2mm, black/white would that work?
    Mar 2015
    35
    Finland, the last place i usually look for anything ...
    Damn close.. it think i will try the 0.8mm stuff and see if i can make it work. As i need the black surface... but then again, i could engrave the 0.2 stuff as negative... hmm.
    Thanks for this!
    Sep 2010
    717
    Quote Originally Posted by monkeyfist View Post
    Thanks for this!
    You could also try face milling (from the back side) to make the 0.8mm -> 0.5mm if that's what you need.. (If you have a router/mill)
    Hub
  1. thin -plastic- materials
    By LaserMark in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2015, 12:46 PM
  2. Thin plastic engraving material
    By brian257 in forum Engraving Machines
    Last Post: 03-01-2013, 10:14 AM
  3. Building a Rockcliff out of thin plastic
    By jazzythumper in forum DIY CNC Router Table Machines
    Last Post: 02-28-2008, 04:58 AM
  4. Engraving Plastic Sign Material
    By Dingo745 in forum Engraving Machines
    Last Post: 08-18-2007, 12:39 AM
  5. RFQ - Cutting Thin Plastic Sheet
    By ukchris in forum Employment Opportunity
    Last Post: 12-07-2006, 03:16 AM
