586,576 active members*
3,562 visitors online*
Results 1 to 4 of 4
    Mar 2015
    35
    max cutting area of 40w china laser
    Hello
    Finally got the laser, but seems i messed up and got the one with smaller cutting area. i though i ordered the one with the 300x200mm cutting area, but it seems the specs say 260x220mm. But the actual cutting area where i can place something to cut, is much smaller. Something like 210x150mm.
    What is the actual difference between these machines, seems the lens assembly can move over about 300x200mm area. What is the limiting factor here? And can i make this a 300x200mm, as the current cutting are is just too small for my purposes.
    Nov 2008
    382
    Re: max cutting area of 40w china laser
    hi
    post a picture that we can see what you realy got
    greetings
    waltfl
    Mar 2015
    35
    Quote Originally Posted by herby08 View Post
    hi
    greetings
    waltfl
    Actually, when i got the software up & running... i seems i can do at least 300x200mm... it's just the material holder that seems to be small. Don't know why it's so small..
    Seem the laser can hit even the air outlet, and the software can command it outside of the possible movable area, and makes a horrible noise. So just need to be careful & build a larger better material holder.
    But why they would advertise this as having a smaller possible cutting area than it has? I do not know.
    So i don't think this is not a problem, just though i had messed up the only thing i was checking when i was buying this ; "buy the one with the larger cutting are" and i messed that up. Pretty lame
    I assume i can adjust the correct max size from here, so it does not hit the sides or the air outlet:
    Ps. Seems i can get about 300x225mm out of this, so i'm happy.
    Mar 2015
    35
    But what is this "running-in adjusment" ?
    And how do i know things, like what model is my mainboard.. there seems to be no model number on it. At least nothing that comes close to the available alternatives.
    Found the model:
    Now the numbers make more sense, as the speeds can go up to 400mm/sec.
  1. china cheapest 1390 laser cutting machine storm1390
    By wklaserliu in forum News Announcements
    Last Post: 01-24-2015, 08:37 AM
  2. China CS4040 Mini. Laser Engraving Cutting Machine
    By lucylucky in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2014, 11:44 AM
  3. laser cutting lathe china
    By mornlift in forum News Announcements
    Last Post: 02-21-2013, 09:57 AM
  4. What's the cutting area of the FSE 40w 4th gen laser?
    By macpod in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-07-2011, 07:39 PM
  5. china laser cutting manufacturer
    By lcshkevin in forum News Announcements
    Last Post: 04-04-2007, 09:48 AM
