Re: upgrade from Mach3
Originally Posted by
HalfRhoVSquared
I've used Mach3 with smoothstepper for quite a while now and find it sort of glitchy. It just does some weird things sometimes and I don't really trust it. Plus I don't like the user interface, it's clunky.
I'm getting a new piece of equipment that will operate very long jobs and I really need to trust my controller board and software.
So I'm looking at other options for controller software that area a step up from Mach3. Need something smooth, fast, lots of look-ahead, very robust, 5-axis capable, and and with a GUI that's easy to use. Affordability isn't at the top of my list but it needs to be at least reasonably priced.
Ideas?
I am not familiar with other controller products but I have used Mach3 with my DIY CNC for years without issues. I know of many users of Mach3 with smoothsteppers without issue as well.
I think if it were the software causing the glitches it would relate to your computer platform's hardware integrity OR your CNC machines wiring integrity. Wiring integrity would be things like connectors, terminal block connections, electrical noise sources spiking into stepper motor control signals, etc. Computer hardware would be things like USB port controllers, CPU cooling, other software running that may draw CPU cycles from Mach3, like anti-virus software ( a really bad player with CNC controller software), or other software that is interrupt driven.
Just some thoughts to consider....
Best,
airnocker
Everything depends on everything else
