586,531 active members*
2,898 visitors online*
Results 1 to 20 of 30
    189
    CNC metal C frame build
    After posting a query regarding the possibility of building a mill from structural steel tubing and then filling the tubes with concrete I've taken the plunge.
    Here the parts are mocked up in my shop with clamps to give me an idea of how the finished machine might look.
    189
    I got everything lined up and welded in place and readied the kiln to stress relieve the frame before grinding/fly cutting the mating surfaces true.
    My wife built a pottery kiln some years back and I was in luck it fit in no problem.
    Next I brought the base and upright to temperature or 1150 degrees for 5 hours.
    When done, I shut off the gas and waited for it to cool.
    It's done when a toothpick comes out clean right?
    189
    Talking
    Here's a CAD file of the design.
    May 2005
    405
    Nice work. I'm a bit ignorant on the use of concrete in steel. Is reducing the strees a requirement for the concrete or for the grinding?
    Paul
    Oct 2006
    64
    Paulc: no expert, but i think you want to stress relieve the steel (or alot of materials) before you final machine the components true to get all of the movement out of the material. IF not stress relieved, if you machine something thinking ur gonna get acccurate parts, the material will move, or spring in some unknown direction, and ur parts won't be what u think ur getting.
    1 So stress relieve
    2 Machining
    3 Sometimes for BIG parts, another round of stress relief
    4 Final maching
    5 inspection
    Jul 2005
    12177
    When you do your machining I suggest you take everything down to within 0.020" of the final dimensions and check to see if things have distorted. You have welded together very different thicknesses and your first stress relieving may not have released all the stresses between these sections.
    189
    It looks as if I will have to have the mating surfaces to the bearing rails ground but will have to have the end of the base fly cut as it won't fit on any grinder in town. This shouldn't be a problem as it would be easy to shim if necessary the uprights to the base.
    L
    Mar 2005
    76
    Good idea.
    Where is a good source for the ball screws etc.
    Why not just use thicker cross section steel instead of the concrete?
    Is there any info on here about using concrete?
    189
    The mill is reall coming along now. It's back from the ginding shop and I've had several days to work on it.
    189
    OK, gang, I'm really getting into it. Here's a shot of the z axis stand-off blocks coming together. Notice the sweet finish the facemill leaves on the aluminum!
    Nice!
    189
    tolerances are looking really good, so far .00005 or better.
    189
    Quote Originally Posted by Bill Johns View Post
    Good idea.
    The concrete will dampen the natural resonance of the steel tubing.
    When unfilled the tubes ring like bells.
    Oct 2006
    64
    nice work so far, keep us posted!
    Jul 2005
    12177
    Good idea.
    This thread is about using concrete and there is a link to a Ph.D. thesis about machine building that has detailed information.
    http://www.cnczone.com/forums/showth...hlight=bamberg
    Aug 2003
    812
    How did you figure half a tenth on a one thou indicator?
    189
    Mill frame has been striped down, painted and ready for final assembly.
    Oh oh!, I broke a tap in the last of the sixteen 1/4- 20 holes that hold down the large THK rails for the Y axis. It was late in the day and the tap was showing it's age.
    I cursed the tap but quickly got to work. I spoke with a fellow machinist last week and he told me about a technique for removing busted taps and bolts. I didn't know how it would work but gave it a try.
    I switched on the power to my TIG welder and dialed the power setting down to a mear 20 amps. slowly I began to heat what little of the tap was sticking up above the rail pad. I began to build up the tap with fill rod until I had a 1/4 inch of so protruding from the hole being ever so careful not to weld the remainder of the tap to the machine itself.
    I slipped a 1/4-20 un-plated nut over the protrusion and welded it to it.
    A minute or so later I gave it a shot of WD-40 and applied a 7/16 wrench to the nut and slowly rocked the nut back and forth. To my joy and amazement the tap simply backed out of the hole and was ready to go after two quick passes with a file to clean up around the freshly taped hole.
    This is a nice way to finish a day's work!
    Mar 2004
    1661
    This machine develops really nicely, looks good to me!
    Mar 2004
    1306
    Nice work. Thanks for posting lots of pictures.
    Are you really planning to use the round rods as linear guides for the Z axis? The flex in those will easily exceed any benefit gained by damping the bed.
    Mark
    189
    No round Thompson slide table was just to get an idea for positioning. Z axis is THK 20 series linear slides and 5/8's ballscrew.
    Quote Originally Posted by RotarySMP View Post
    189
    Basic machine is nearly complete. Will post some more pics soon.
