586,389 active members*
3,196 visitors online*
    Apr 2015
    12
    Slanted letters
    I have my engraver up and running, but when I engrave a name the letters are all slanted? Does anyone know what would cause my design to come out slanted? It is straight along the bottom, but each letter is tilted? Thanks, stephanie
    Jan 2008
    940
    Re: Slanted letters
    check your belts they may be a little loose and your head moves over just a little each pass
    Apr 2015
    12
    Re: Slanted letters
    Thanks. We checked all the belts and they are all tight. Letters are still slanted?
    Apr 2004
    475
    Re: Slanted letters
    Only reason is that y rails are not 90deg to x rail. You'll need to adjust by loosening screws and re-tighten.
    Re: Slanted letters
    Here's an lesson from Thunder Laser may help you:
    Why engraving edge out-of-straight
    good luck.
    www.thunderlaser.com
  1. Machining along a slanted surface
    By Si14 in forum G-Code Programing
    Last Post: 02-01-2014, 10:50 PM
  2. Thread Mill Wizard - Slanted thread produced
    By ngr1 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-22-2012, 07:23 PM
  3. Letters, Letters & Letters
    By Joe Crumley in forum Signmaking Topics
    Last Post: 11-20-2011, 03:46 AM
  4. straight line sloped/slanted
    By lasernewb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-30-2011, 12:50 PM
  5. boss on a slanted surface
    By XXF in forum Haas Mills
    Last Post: 01-31-2006, 05:29 AM
