I make many round parts that are similar in shape but not quite identical. My idea is to make a fixture plate with a solid angle block for one “jaw” and a detachable “soft jaw” to account for various shaped parts of similar (but not the same) form. The detachable jaw would be held vertically in place by shoulder bolts with accompanying slots to allow for some play in the horizontal plane. The jaw would then be tightened horizontally by 2 mitee-bite pitbull clamps per 3 parts. I would end up making several soft jaws for various parts, but they would all be pretty similar.
I’ll start off parts as 1.25” round aluminum stock, machine them down to am OD of 1.15” inches (with flats for locating) and place them in a stepped jaw.
Would a fixture like this work? Or would there just not be enough clamping force? Pictured is a smaller test part that I would make as a final proof of concept. In the end, I would make a much larger plate of similar design to take full advantage of the Tormach’s travel. I would bolt it directly to the table. This prototype is 6” long and would simply be held in a vice.
