586,409 active members*
2,858 visitors online*
Results 1 to 2 of 2
    Jul 2009
    419
    6 hour Q&D dual finishing system
    First small setup for my vibratory finisher is working:
    vibratoryfinish.mpeg - YouTube
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Jul 2009
    419
    Re: 6 hour Q&D dual finishing system
    Few years on, system is being used for production, a few days per year.
    Has been encased in 35 mm osb case to keep noise in. Motor is on the outside of the case and can be removed/disconnected in 2 seconds. Reconnecting takes 30 seconds.
    Tub holds 30 kilo's of 3 mm and 2.8 mm stainless balls.
    Sven
  1. Dual Saw Portable Track System
    By infomatrix in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-18-2013, 07:47 AM
  2. Dual Steppers or Timing Belt for Dual X-axis?
    By GEBrown in forum Linear and Rotary Motion
    Last Post: 05-27-2010, 05:45 PM
  3. Dual Z axis and Dual Spindle
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 08-28-2008, 09:15 PM
