586,545 active members*
3,077 visitors online*
IndustryArena Forum > CAM Software > Mastercam > This is going to sound just plain dumb on my part.
    Oct 2004
    84
    This is regrading X Form, Offset Contour. This is in MC X-4.
    I select the Offset Contour operation, the Chaining Selection Box comes up and I select the chain or chains I wish to resize and click the Green Arrow.
    Then the Offset Contour Box comes up and I input my changes.
    Now, get this. The Offset Contour Box is so "tall" on my screen, the Green Arrow Button is below the edge of my monitor. Even when I shift the Task Bar to the side of the monitor, the Offset Contour Box is still too long and doesn't expose the Green Check Button. I can't confirm this op.
    I fooled around with screen resolution, but to no avail. I will be humbly embarrassed and thankful to be told how simple the fix to this becomes.
    Dec 2008
    3110
    Re: This is going to sound just plain dumb on my part.
    No, not as dumb as you think.....I may also be incorrect in the solution
    - R-click in the upper toolbar grey area to reload your default toolbar layout ( probably the "Design" )
    Apr 2003
    3578
    What is your screen res actully. are you on a laptop or desk top? what size screen?
    Cadcam
  1. V3-Clearance Plain
    By rckdef in forum BobCad-Cam
    Last Post: 08-23-2013, 08:13 PM
  2. NEED HELP-CLEARANCE PLAIN
    Last Post: 05-23-2013, 12:57 AM
  3. Dumb question, but not so dumb??
    By gixxergary in forum Haas Mills
    Last Post: 01-10-2012, 01:30 AM
  4. Feed Plain
    By jaangi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2008, 11:10 AM
  5. plain language to iso
    By delbert in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2006, 04:59 AM
