586,419 active members*
3,022 visitors online*
Results 1 to 10 of 10
    Apr 2013
    1788
    At the limit!
    I shutdown PP with my Y-axis at the limit switch. Upon restart I get "Y axis limit switch active" and RESET is flashing red. This is correct but if I click RESET I get the same message again so I can't jog the Y or reference Y to fix the problem. What do I do?
    Nov 2005
    218
    Re: At the limit!
    You can turn off the limits temporarily in the settings.
    Apr 2013
    1788
    Re: At the limit!
    I tried that but it doesn't appear to let me reset/
    Jul 2004
    1424
    Re: At the limit!
    What version of PP do you have? 1.7.2 solved the problem of not being able to jog off the limit if you started up at it.
    Tim
    Apr 2013
    1788
    Re: At the limit!
    I installed 1.7.2 earlier today so I guess that the problem is not quite fixed.
    Jul 2004
    1424
    Re: At the limit!
    Make sure you post the bug on the PP bug reporting page.
    http://www.tormach.com/pathpilot_tracking.html#issues
    Tim
    Apr 2013
    1788
    Re: At the limit!
    After much futzing about on Sunday I removed the limit switch bracket. This allowed me to move the table and get back to work. The problem occurred when booting on the limit switch. If you hit the limit switch after power up things work as with Mach. I'll see if I can reproduce it tomorrow.
    Jan 2008
    458
    Re: At the limit!
    Expect this to be an ongoing issue- there is no way you can write a software for such a limited market and have sufficient resources to fully de-bug it. Microsoft has untold numbers of the best software engineers in the world and still came out with Vista. Tormach will have to rely on their customers to do the de-bugging.
    Apr 2013
    1788
    Re: At the limit!
    It is probably bad form to reply to my own thread but...
    I tried to reproduce the problem this afternoon and it appears that I was mistaken. My excuse is that repeated error messages such as "Y axis limit switch active", "Command cannot be executed unless machine is powered on and the control software is out of RESET condition" and "Must take machine out of estop before jogging" for each attempt to move the table confused me. If you click on "Reset" you can actually move the table slightly (by 0.01-inch?) for each mouse click. My apology for any confused caused.
    Jun 2005
    656
    Re: At the limit!
    Good to know that works.... the error display could use some cleanup IMO.
  1. VF-2 HRT-160 Limit
    By vdauer in forum Haas Mills
    Last Post: 04-26-2012, 06:26 PM
  2. Limit of Cat 40 Tooling
    By 69owb in forum CNC Tooling
    Last Post: 01-06-2011, 09:06 PM
  3. limit on subroutines,only six?
    By oreos40 in forum G-Code Programing
    Last Post: 12-24-2010, 05:53 AM
  4. Limit Switches - Ugh
    By fasto in forum HURCO
    Last Post: 11-09-2010, 11:50 PM
  5. limit switches
    By terrydullaway in forum CNC Machine Related Electronics
    Last Post: 09-28-2005, 11:37 AM
