586,493 active members*
1,072 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Need some advice on buying a SpectraLight mill
Results 1 to 5 of 5
    Aug 2012
    279
    Thinking of buying a SpectraLight mill and wondering what one is worth that needs a bit of work. It's said to have updated motor drivers but isn't fully working, mechanically in good condition. I am new to CNC but not to electronics so getting it running shouldn't be too bad even if I have to replace some electronics bits. Down the road I would like to have a CNCed G0704 for some steel milling and a bit bigger work but this seems pretty good to get started and learn software and tools without taking up much space. If and when I move to a bigger machine I figure I can sell it. Or am I going to put so much money/time in other tooling that I should just go for the bigger mill to start?
    I have read that at least some had unipolar step motors originally and I think the bipolar motors are preferred - some of the upgrades mention changing to bipolar steppers. Anyone know what motors they came with originally?
    Any thoughts? What sort of things should I be looking for or looking out for when I look it over? I have a fair amount of general machine experience but none with mills.
    Nov 2009
    4415
    Re: Need some advice on buying a SpectraLight mill
    Is this a Sherline based machine? If so, they are alright and will give you the opportunity to learn. You will get frustrated cutting metals but it can be done.
    On the other hand, if you want a G0704 eventually just buy 1. There is no need for too many machines laying around.
    A lazy man does it twice.
    Jan 2007
    175
    As Fastest1 mentioned it will be good to learn on, and not very speedy for metal cutting
    We recently did a few of these small sherline mill retro-fits for cutting and a couple were made into 3D printers, for some local schools,
    The main issues where old controls, and the worn fine pitch drive screws, the slides were actually in good shape considering the amount of use, and being made from aluminum
    If it is a sherline, you should still be able to buy parts for it, the one's we did where all upgraded to acme 1/4" 4 start which helped huge with speed as compared to the 1/4-20 that are in them
    here's a bit of info for you Sherline Mill to 3D Printer Conversion
    Rockcliff Machine Inc.
    http://www.rockcliffmachine.com
    Nov 2009
    4415
    I did that same thing a few years ago,
    https://youtu.be/1XqlivRhLCc
    Jan 2007
    175
    Fastest1 - Nice 3D Printer Looks like great quality prints too
    I have still been using our cnc router for printing, swapping between print head and spindle when I need to print or cut, but lately I have been considering building dedicated printer, and definitely going with Mach3 as the control.
  1. Looking at buying an acroloc mill and would like some advice
    By snowluck in forum Want To Buy...Need help!
    Last Post: 12-03-2013, 05:22 AM
  2. Buying CNC mill need advice
    By ready961 in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2008, 02:10 AM
  3. Buying CNC mill, any advice?
    By Haeusser in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2007, 04:06 PM
  4. Just bought Spectralight, CNC N00b- advice?
    By Sporqster in forum Benchtop Machines
    Last Post: 08-09-2006, 09:05 PM
  5. Advice / help? - HobbyCNC upgrade for SpectraLight 0200
    By Sporqster in forum Hobbycnc (Products)
    Last Post: 06-16-2005, 03:55 AM
