Hello, Desperately need help wiring my spindle drive. PDMX-107 to Fuji AF-300E$.
The machine is a very heavy duty industrial router that I have been retrofitting with Mach3 controls.
My setup is..
- PC with Mach3
- Ethernet Smooth Stepper
- PMDX-126 breakout board
- PMDX-107 Spindle control daughter board.
- 10hp Colombo Spindle.
- Fuji/GE AF-300E$ drive. (IDK if VFD,PWM,VSD ?????)
- Rail mount spindle monitor. (IDK, see picture, may control the analog load meter on machine???)
Although my spindle is capable of 25k rpm I would like to use this machine in lower RPM.
Will be using it for machining plastics. Not routing wood. Would like to also be capable of
very low RPM and reversing. (ability to do rigid tapping would be wonderful)
Any help would be greatly appreciated.
[FILES & PICTURES ATTACHED]
