586,430 active members*
3,958 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc spindle driveA06B-6055-H122
    Dec 2010
    11
    Hi every body,
    please help me !
    I have one Hurco BMC 30 whith Fanuc Drivers. When power on the spindle driver appear : AL 17..
    Could you help me with the meaning AL 17? Or better or better with significance and other alarms signs . Where to find them , because Fanuc is very very hermetic . Can a user manual anyone help me to download it? .
    My driver is the type AO6B -655 - H122
    Thank you
    Dec 2010
    11
    Re: Fanuc spindle driveA06B-6055-H122
    Dec 2006
    310
    Hello
    Error seems to be related to NVRAM on Spindle PCB
    To initialize the NVRAM:
    1. Power down.
    2. Move shorting pin (S1) to TEST position.
    3. Power on.
    4. Hold all four switches until FFFFF is displayed.
    5. Hold the MODE button and press the UP button until FC-22 is displayed.
    6. Hold the DATA SET button until GOOD is displayed.
    7. Power down.
    8. Move shorting pin back to normal position.
    9. Power on.
    This procedure is necessary when the NVRAM has been replaced or when alarm 17 or 23 has occurred. Anytime you have an alarm which will not go away, you can try this. Alarm AL-23 must be cleared this way, it will not go away by cycling power.
    Regards
    Dec 2010
    11
    Thank you,
    M.Rishikes it is work.
    I had some problems until I could find S1.
    Jan 2010
    56
    Thank you M.Rishikesh, your post also Helped me a lot. AL-17 gone..By the way, is there any way on how to backup Spindle drive Parameters?
    Sent from my SM-G903F using Tapatalk
    Dec 2006
    310
    Quote Originally Posted by koch.Cnc View Post
    As far as I know, there is no procedure to backup except manual recording
  1. Replies: 2
    Last Post: 12-19-2014, 04:06 PM
  2. Replies: 12
    Last Post: 07-25-2012, 11:10 AM
  3. fanuc spindle a06b-6055-h106 driver manuals
    By johnmoon in forum Fanuc
    Last Post: 12-13-2011, 10:03 PM
  4. fanuc spindle AO6B-6055-H115
    By eastcomms in forum Fanuc
    Last Post: 12-13-2011, 05:01 AM
