586,655 active members*
3,161 visitors online*
    Apr 2015
    27
    Opti BF20L CNC conversion
    Hi All,
    I am looking at converting my bf20l to cnc. But I'm curious why the optimum ballscrew kit is a bolt on kit vs any other ballscrew kit which requires milling the Y table? is it the fact the ballscrew nut is bigger? cant you just machine the ballscrew nut instead of the table?
    Cheers,
    Apr 2015
    27
    Re: Opti BF20L CNC conversion
    Anyway I got my CNC Nema34 Motors today. Im wrapped.. I got a breakout board with it and I will probably use it.. But At the moment for testing and a big maybe, I have it hooked up to an Arduino running GRBL and it works!
    The ramp up speed and slow down speed is rather slow.. So I found $120,121,122 are the acceleration settings which I have stepped up to 50
    the max rate they can run is around 7000 to 7500.. 900 each axis stalls seperately.. and at 8000 when running 2 axis they stall.. so probably 7000 is good
    Anyway I hope this helps.. ill put up pics soon
  1. Opti BF20L New to Milling
    By speed_racer in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2015, 02:08 AM
  2. Optimum BF20L CNC conversion using the Smooth Stepper
    By Mad Welder in forum Benchtop Machines
    Last Post: 03-25-2013, 12:47 AM
  3. thinking a cnc conversion on a BF20L (g0704 clone)
    By AchillesGr in forum Benchtop Machines
    Last Post: 12-29-2012, 06:24 PM
  4. Replies: 72
    Last Post: 06-03-2012, 12:50 PM
  5. Optimum BF20L CNC conversion
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2009, 05:09 PM
