586,471 active members*
3,609 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Mitsubishi MV5C S.No V53062 with Fanuc 21M
    Dec 2006
    310
    Dear Sir
    subject machine was working fine till last
    Wednesday then it stopped due to
    vibration in y axis
    we found water seepage into the motor
    Also motor bearings gone bad. Now
    motor repaired everything looks
    normal including insulation resistance
    after varnish
    NOW WE GET ERROR 400 OVERLOAD
    We don't find any problems in voltage etc
    Kindly advise
    Feb 2015
    161
    Re: Mitsubishi MV5C S.No V53062 with Fanuc 21M
    Connect the thermistor in the motor to the feedback cable.
    This alarm is just a disconnection of that thermistor.
    Oct 2008
    29
    After you got the motor repaired, did you get the encoder re-aligned to the motor shaft so that the poles are in line with the coder signals?
  1. Mitsubishi MV5C S.No V53062 with Fanuc 21M
    By M.RISHIKESH in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-09-2015, 03:31 PM
  2. Mitsubishi FA20 vs Fanuc 1ia
    By caner91 in forum EDM Discussion General Topics
    Last Post: 06-17-2014, 08:24 PM
  3. Mitsubishi S.No. V53062 M/c MODEL No – MV4C/MV5C
    Last Post: 03-01-2013, 08:12 AM
  4. Mitsubishi MV5C tool changer is in a bind!
    By Markemory in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2009, 05:34 AM
  5. Fanuc or Siemens or Mitsubishi
    By dumonts in forum Polls
    Last Post: 11-23-2005, 03:15 AM
