586,125 active members*
2,906 visitors online*
    Georgie Guest
    Z axis ball scre RF25 etc
    I have Converted my Eagle25 to 3 axis, I don't like the Z axis driving the Quill with a belt and gears.
    Can anyone share a Ballscrew driven quill ? I would be very grateful,
    I'm sure I have seen one example but I can't find it!
    Many thanks
    George
    Aug 2008
    962
    Re: Z axis ball scre RF25 etc
    This is one of the best I've seen ..
    Enco Drill Mill
    Georgie Guest
    Thanks gd.
    I mailed Jeff but no response. His conversion was 2001 era so he may not be around any more,
    Kelly Regan also posted a great design but again I tried to contact him with no luck at all.
    Chers
    George
    Jun 2007
    149
    The best way is make 3 or 4 split clamps identical which clamp onto the 115mm dia column. Design a plate to bolt onto it with either dovetail or ballrails, buy a use bf20 lathe milling head attachment.
    It can all be milled on the mill itself and you'll have a column that is more rigid and can be swivelled 90 degrees to the side enabling the spindle to be used as a horizontal.
    Win win situation.
  1. RF25/30 Drill Mill CNC conversion FINISHED!
    By rotec in forum Benchtop Machines
    Last Post: 06-01-2016, 01:14 PM
  2. Eagle/RF25 conversion-ball screw help please
    By Georgie in forum Benchtop Machines
    Last Post: 05-07-2016, 05:23 PM
  3. RF25 conversion
    By Lance Reid in forum Australia, New Zealand Club House
    Last Post: 06-04-2009, 01:40 AM
  4. sequential cycle rotary engine (SCRE)
    By dr kingston in forum I.C. Engines
    Last Post: 03-22-2007, 10:34 PM
  5. BF20 or RF25
    By BMaynard in forum Benchtop Machines
    Last Post: 08-06-2006, 12:31 AM
