586,598 active members*
3,577 visitors online*
    Feb 2011
    Mach 3 and Ecocam EOT-2 Tangential Knife
    Hi All,
    I have installed this Tangential Oscillating Blade on my router, and got it working to a degree.
    I have had to install a separate power supply for the oscillating motor, and Mach 3 controls the tangential aspect of the machine quite well.
    However...... has anybody wired up the position sensor before.... I have tried to get it to work using the limit/homing signals on Mach 3, but to no avail. The Manual on the EOT-2 does say that there is a position sensor, and even after giving power to the relays etc, no signal comes back.
    Has anybody set this up before ?
    Kind regards
    Barry Collins
    Sep 2012
    4
    Re: Mach 3 and Ecocam EOT-2 Tangential Knife
    Hi Barry
    Yes I was able to set it up, but forgive me if I can't recall it right away. Sice I moved my hobby room is 20min away and with two young kids its not easy to get some CNC time.
    If you still need it, I can look it up for you, but it takes a moment.
    Dani
  1. EcoCam Tangential Cutters
    By Eric Olson in forum CNC Tooling
    Last Post: 04-24-2020, 06:43 PM
  2. Rubber cut with tangential knife
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 12-03-2012, 11:05 AM
  3. Tangential Knife Setup Help !!!
    By Clax in forum Mach Software (ArtSoft software)
    Last Post: 11-11-2009, 03:42 PM
  4. support for tangential knife??
    By SSN Vet in forum Mach Software (ArtSoft software)
    Last Post: 02-26-2009, 02:29 AM
  5. Add a tangential knife option
    By avengine in forum Community Club House
    Last Post: 04-13-2006, 12:40 PM
