I finally got this machine up and running on all 4 axis. I've run numerous programs with small tooling in aluminum and mild steel. I started a new part that's made of annealed 316L and it basically has a few .75 slots 1.375 through the part. Long story short while drilling the first hole through the part the head stalled. I was standing there with my finger on the stop button so I stopped the machine and raised the z axis. As soon as the z axis moved the spindle took back off. It never alarmed so I'm thinking the belt is slipping. From what I've gathered this is a direct belt driven system with no gear change system. My question is: Is there a procedure to tighten the belt or replace it. Or does this machine have no balls. Most of the machines I've run and programmed over the years have been 7 hp and I've never had a problem drilling a .437" hole 1.375" deep at 480 RPMs and 1.7 ipm.
Any help is appreciated
