586,392 active members*
3,240 visitors online*
Results 1 to 6 of 6
    May 2004
    35
    X3 Y-axis Extension
    I have ordered the Deluxe conversion kit from CNCFUSION. I asked for the Y axis to cover 6-3/4”. I have been informed that they will only furnish the Y in stock 5-3/4Therefore, I am thinking of adding a Tee shaped end to the Y axis screw to allow the screw to over-travel. Also I believe I can add a spacer and recover some travel lost to the longer ball nut. Any comments are appreciated.
    Thanks,
    Jimbo7
    May 2004
    35
    Re: X3 Y-axis Extension
    All,
    I found the information on Crevice Reamer's site. I will do something similar.
    Thanks,
    jimbo7
    Feb 2010
    371
    What I did on my X2 was reverse the nut so that it was facing the front of the machine, and using a hole saw, cut a larger hole in the base that the nut could pass through. That gained me quite a bit on the Y Axis.
    May 2004
    35
    AiR_GuNNeR,
    Thanks for the suggestion. I am not sure how that applies to the X3 mill. I am planning to have the flange turned to the mill column side. I am speculating now as I am waiting on my CNC Fusion Kit to arrive. It should be here in about 1 to 2 weeks. I will have a better idea of what is required then.
    Thanks for your reply,
    jimbo7
    May 2004
    35
    I have received my kit from CNCFusion. Awsome set of parts. The screws and parts are assembled by axis. My concern was the Y axis. I checked the total travel available and found it was 6-1/2". No mods to the Z column. No mods needed for the Y axis screw. Lock nuts on all screws.
    I just need to get to work on installing.
    Great work and thanks to CNC Fusion.
    Thanks,
    jimbo7
    Dec 2005
    8
    Hey Jimbo7,
    I am just about to embark on the journey of CNC'ing my SX3. I just created my very first post ( after 10 years being a member of CNC Zone ) about CNC fusion ball screws. If you have a chance you might be able to answer ?
    http://www.cnczone.com/forums/x3-sx3...ml#post1769126
    Jake
  1. X2 Y Axis Way Extension
    By degreaser in forum Benchtop Machines
    Last Post: 12-09-2012, 05:16 AM
  2. New Z-Axis Extension for Taig ?
    By BuzzSaw in forum Taig Mills / Lathes
    Last Post: 02-07-2011, 09:45 PM
  3. X axis extension?
    By pixel8tryx in forum Taig Mills / Lathes
    Last Post: 06-15-2010, 07:15 PM
  4. How much to cut for y axis extension?
    By kimoyo in forum Charter Oak Automation Support Forum
    Last Post: 06-25-2009, 08:50 PM
  5. X2 Y-axis extension
    By X2cnc in forum Benchtop Machines
    Last Post: 12-17-2008, 04:14 AM
