586,796 active members*
2,572 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Lowering Voltage on Power Supplies?
    Question Lowering Voltage on Power Supplies?
    Howdy all,
    Here is what I got.
    My 1100 oz/in servos are rated @ 48 VDC .33 amps no load.
    I'm using 320 Geckos.
    Right now I've got two power supplies hooked up @ 52 VDC 16 amps.
    I have three 52 VDC 8 amp power supplies available to me.
    I'm getting 132 ipm with my 8 tpi ACME now on rapids which is livable but hey I can handle more.
    Now if I hook two up to get 104 VDC how can I downgrade the volts to get 70 or so volts?
    I was told a rheostat might work?
    Any thoughts?
    Dasigntist
    Never forget that only dead fish swim with the stream
    Malcolm Muggeridge
    779
    You don't want to supply more voltage to your servos if they are rated at 48 VDC, then use 48 VDC.
    Read the reply from Mariss of Gecko drives in this thread. http://www.cnczone.com/showthread.php?s=&threadid=2657
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    I did and I thought I'll just be happy with what I have.
    Thanks for the response.....
    Dasigntist
    Malcolm Muggeridge
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  2. Connecting Two Power Supplies
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 03-19-2005, 01:03 AM
  3. power supplies
    By itsme in forum Xylotex
    Last Post: 02-21-2005, 07:40 PM
  4. Computer power supplies
    By flannman in forum CNC Machine Related Electronics
    Last Post: 12-22-2004, 05:45 PM
  5. These power supplies useful?
    By jlawren6 in forum CNC Machine Related Electronics
    Last Post: 08-26-2004, 02:19 AM
