Originally Posted by
dannad
Thanks for the reply Tim. This is very helpful information. I still have a question about the wiring, though. Figure 3-3b (scan0003.jpg) shows the sin and cos signal pins as pins 8 and 7, respectively, but I can't tell why the other pins are there. It looks like there are some specifications on pins 1 and 5, but I can't read them. Are the power supply pins 1 and 5? If so, do you know what voltage levels they require?
Also, do you have any idea what type of display would work if the sensors are OK? Thanks again ...
