586,955 active members*
2,826 visitors online*
Results 1 to 11 of 11
    Feb 2015
    11
    Question Plasma quench
    I found this recipe
    1/4 pound of sodium nitrite powder
    1 teaspoon of Physan 20
    1 oz Ultramarine blue food-grade dye
    Why add ultramarine blue dye ?
    anyone have problem with this homemade plasma quench?
    thank for answer
    pun
    Jun 2009
    226
    Re: Plasma quench
    I've been using this for 4 years with no problems and absolutely no rust. Make sure you get "Nitrite" and not "Nitrate". Sodium nitrite is used in food preservation so it should be safe for the quench. I also use it to keep metal pieces from rusting (just dunk them in unused quench) before they are clear coated.
    Willy
    Jan 2007
    599
    Re: Plasma quench
    I suspect that the food dye is used to let people know its not water, however giving something a blue color does not insure nobody will drink it. Roundup is blue, my son drank some of it, luckily never swallowed it.....
    Feb 2015
    11
    Re: Plasma quench
    Thank willy
    How often you change Plasma quench or just add water
    Jan 2011
    91
    Re: Plasma quench
    I use it as well, works great. I add more sodium nitrite when I add water.
    Jun 2009
    226
    Re: Plasma quench
    I have a small table. The water tray holds about 11 gallons. I add about 1/2 gallon per day for the evaporation. About every second week, I add about 1/2 the quench chemicals (for 11 gallons) and this seems to keep everything in check. No rust, no algae, and it doesn't cost much.
    Willy
    Feb 2015
    11
    Re: Plasma quench
    willy do you have any rust problem on component like a rack and pinion or linear rail from water splash.
    thank you
    pun
    Jun 2009
    226
    Re: Plasma quench
    No problems at all.
    All of my rails and unpainted steel surfaces/ screws on the machine are as clean as they day I installed them.
    As I mentioned before, I dunk metal art pieces in some clean quench if they are going to sit a while before I am going to paint or clear coat them.
    You won't have any problems with this recipe.
    Willy
    Aug 2005
    413
    Re: Plasma quench
    How many gallons is recipe good for? No problems with the nitrite changing to something else under the plasma jet?
    Nov 2009
    159
    Re: Plasma quench
    Alot of different substrates of Sodium will work. Sodium bicarbonate is another
    Now featuring Plasmaland online
    Feb 2015
    11
    Quote Originally Posted by BTA PLASMA View Post
    Do you have recipe for sodium bicabonate
  1. Plasma Quench Source ?
    By mjp in forum Waterjet General Topics
    Last Post: 02-09-2015, 05:42 PM
  2. Plasma Quench Alternatives
    By rock4xfab in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-15-2012, 10:53 PM
  3. Non-Freezing Plasma Quench?
    By vacextar in forum Waterjet General Topics
    Last Post: 11-09-2011, 04:05 PM
  4. Anyone ever use coolant oil for plasma quench?
    By Danno in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-06-2011, 03:36 AM
  5. How far should the plasma quench be from the workpiece ?
    Last Post: 10-05-2011, 02:32 PM
