587,040 active members*
2,718 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Setting up meshcam 4th axis machining?
    189
    Having some issues with setting up meshcam to cut a 3d STL file.
    I think the problem is how the part is placed in meshcam so far as Z zero is concerned and possible how the machine (4 axis mill) is set to zero.
    I've been setting up the mill with all axis zeroed to home position and after choosing a cutter I zero the Z axis so that the tip of the cutter (ball end mill) is right at the center of rotation of the A axis.
    Getting some distortion on my parts sometimes.
    Anybody have a step by step on how to set up a part in meshcam and then how to set up mill to carve correctly?
    Thanks!
    Is a sentance fragment?
    Apr 2003
    178
    Re: Setting up meshcam 4th axis machining?
    The setup sounds correct. How are you finding the center of rotation and how distorted are the parts?
    -Rob
    189
    recalibrating the mill today. Will run a test in the next day and report back my findings.
    189
    Part is not carving properly. Looks like Z depth is too great. I have the z axis zeroed with the tip of the end mill at the exact center of rotation of the A axis.
    Here's two pics of the finished carving.
    I'm attaching the meshcam file. Just change the venus.zip to venus.mcf to open in meshcam. (CNCzone won't allow me to upload with .mcf extension)
    Attached Files Attached Files
  1. Cutting Depth Issues with 2-Sided machining on MeshCAM
    By Skump in forum Uncategorised CAM Discussion
    Last Post: 01-06-2014, 07:01 PM
  2. Replies: 0
    Last Post: 10-24-2013, 04:49 PM
  3. MeshCAM 4 Build, 2 sided machining
    By ViperTX in forum Uncategorised CAM Discussion
    Last Post: 10-09-2010, 09:37 PM
  4. Machining Multiple Parts in One Setting
    By bobby1 in forum BobCad-Cam
    Last Post: 04-30-2007, 07:16 AM
  5. Ejector pin machining? Length setting?
    By DomB in forum Moldmaking
    Last Post: 12-30-2006, 10:21 AM
