And if you like engrave you dot is smaller so you can make high quality engraves. With 38.1 lens power is allmost double, dot is smaller and you can cut max 6-7mm. I cut 4 mm birch plywood 20% and 10mms. It cuts 16% but because i need high quality i use 20-23 %
