586,521 active members*
3,626 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Finishing the outside of vertical boss with an irregular base....
    Mar 2015
    Imagine simple round boss sticking straight up out of a flat plate (or a cylinder sticking out of a plate) . Its pretty easy to contour around this boss and finish the outer surface of the cylinder. How do I do this exact same thing, when the surface at the bottom (that the cylinder is sticking out of) is not flat, but irregular, fluctuating up and down in Z? I have a fairly complex part that I have already performed a number of Surface Rough, Finish and Surface Highspeed Scallop tool pathes on. I am happy with everything except the finish on the outside of this boss. I want cut 2d contour type finishing passes around out, while having the ball mill move up and down to avoid hitting the complex bottom surface. Ive included a few pics so you can maybe understand what I am talking about. I am really just looking for some guidance as to what tool path to use in order to accomplish this.
    If you zoom in on the second or third picture you can see where the tool pathes constantly move in, touch the boss, then lift up and over it. As far as the surface finish on the rest of the part is concerned, this is exactly what I am looking for. However, I want to leave a smooth contoured finish around the boss. Does anyone know if there is a way that I can program a finishing contour that forces the end mill to follow the contour I drew in the last picture?
    Id love to hear your thoughts!
    Attached Thumbnails Attached Thumbnails ScreenShot1.jpg   ScreenShot2.jpg   ScreenShot3.jpg   ScreenShot4.jpg
    Mar 2012
    109
    Re: Finishing the outside of vertical boss with an irregular base....
    Try Xform > Project. Select the edges you want to run your contour around, and project them all up to the top surface, and then use that as your new chain. That's assuming you want to run it as a 2D contour. Running it in 3D be a bit problematic, and I'll leave that to someone else to solve.
    Apr 2015
    31
    Quote Originally Posted by HoosierDaddy1 View Post
    Have you tried making the surfaces you don't want to touch your check surfaces in your solid operations and set your parameters to leave .002 thousandths on the check surfaces. Also I'm not sure but an opti core path with a hybrid path to finish might yeild smoother transitions.
  1. milling 1.5mm radius irregular boss with 3mm mill
    By gibrocksonne in forum CamWorks
    Last Post: 11-02-2014, 09:02 PM
  2. How do you get the base of a mill square with the vertical column?
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 07-14-2013, 06:16 PM
  3. How to get an Irregular Surface cut?
    By RMS in forum BobCad-Cam
    Last Post: 12-22-2010, 11:38 PM
  4. Finishing Vertical Surfaces
    By jt83byrne in forum MetalWork Discussion
    Last Post: 06-30-2010, 07:52 PM
  5. Pulses irregular ?
    By tmead in forum Machines running Mach Software
    Last Post: 10-08-2008, 05:01 PM
