586,593 active members*
3,058 visitors online*
Thread: Z Axis woes
Results 1 to 4 of 4
    Oct 2007
    49
    Z Axis woes
    Interesting that COA website states 200InchesPerMinute for X and Y but nothing for Z?
    I am shocked at the 200IPM ! This seems in-feasibly fast. Does anyone have video of an RF45 mill moving at that speed?
    Anyway... 3000 mm per minute turned out to be a bit quick for my Z axis motor, I suspect it was quite warm already, I have a 24K RPM spindle strapped to the side of the head and made some adjustments to code I was running, the first time this new code hit the Z axis with a lift... it lifted no more. What speed is recommended for Z axis lift?
    rotating the Z ball screw by hand reminded me I need to revisit the idea of a counter balance, any pointers to successful counter balance implementations appreciated.
    Thanks,
    Jon
    Sliding down the razor blade of life.
    Oct 2007
    49
    Re: Z Axis woes
    Well the good news is that the Z axis motor is fine
    Basic troubleshooting of swapping round the SpeakOn cables for another axis was enough, no idea what the problem was (other than it being driven faster than ever before..)
    I am going to make a counterbalance though as it seems very unfair on the Z axis motor.. suggestions still appreciated, I am guessing it is about 75Kg, the second spindle is only 2 maybe 3 Kg and at some point I will get round to building an ATC.
    The counterbalance ties in with my ATC plans, I hope to use bellville springs at the top of the drawbar to (pull) the drawbar and to simply raise the Z axis into a fixed lump to release the drawbar. However that is not going to happen immediately.
    Jon
    May 2008
    1185
    Re: Z Axis woes
    The Z heavy so its hard to get much over 100 but the X and Y is easy to go fast.
    How about 300 IPM.
    https://www.youtube.com/watch?v=M299KWBsuBs
    I still set it at 100.
    The new IH servos are much more powerful than the one I have.
    youtube videos of the G0704 under the name arizonavideo99
    Oct 2007
    49
    Re: Z Axis woes
    Yes I made a mistake. Windows calculator in programmer mode does not take decimal places, it seemed wrong and I retyped the calculation and then accepted it... 200IPM*25.4=508000mmPM very wrong
  1. Z Axis woes
    By Thorpydo in forum Benchtop Machines
    Last Post: 09-29-2009, 05:37 PM
  2. Continuing 4th axis and electrical gremlin woes
    By ralph@nes in forum Haas Mills
    Last Post: 11-27-2008, 03:55 PM
  3. Bridgeport Series II VMC - X and Z axis woes
    By inthezone in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2007, 03:59 PM
  4. Z-axis design woes
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 06-17-2004, 02:31 PM
  5. Z axis woes
    By yukonho in forum DIY CNC Router Table Machines
    Last Post: 02-29-2004, 07:02 AM
